Porsche 914 2.0L hydraulic lifter & pushrods, Need to replace lifters & push rods |
MFejsa |
Jan 31 2021, 02:53 PM
Newbie Group: Members Posts: 40 Joined: 25-April 20 From: Saudi Arabia Member No.: 24,178 Region Association: None |
Hi, 2 of my hydraulic lifters have failed on my Porsche 914 2.0L (GA engine). When the lifters failed it also bent one of my push rods.
I am going to do an AApiston cylinder / piston replacement but also need / want to replace all the lifters and push rods. I've measure my push rod and its 10.3 inches long. Questions below: 1. Are all lifter brands the same length? 2. Can someone recommend a replacement lifter and compatible push rod length? If so, please provide website, brand and length of push rod. Regards Michael |
Mark Henry |
Jan 31 2021, 04:09 PM
The 914 never had hydraulic lifters, so that's a modification by a PO. The lifters were used in the VW bus (van, kombi) from IIRC 1978-83.
Failing lifters, are often the result of poor tolerances of the lifter bore. This can not be fixed by simply replacing the lifters. Mechanical lifters are more mantainance (adjustments) but will out last hydraulic lifters. Personally I'd get a Web camshafts #73, new matching lifters, and stock aluminum mechanicial pushrods. |
914werke |
Jan 31 2021, 04:14 PM
"I got blisters on me fingers" Group: Members Posts: 10,119 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
(IMG:style_emoticons/default/agree.gif) its a PO mod. You may also want to scope the piston crowns & determine if you have bus (low compression) pistons also.
Source OE push rods out of a bus & buy new Hydro lifters, set up the lash correctly, and make sure you dont have any oiling problems Short of splitting the case & replacing the cam & all the associated valve train items Its your shortest path to getting it back operating. Attached image(s) |
MFejsa |
Feb 3 2021, 11:01 AM
Thanks for your response Mark. I think I got a dud engine. Im sourcing another replacement engine now as I dont know what else is wrong with it. Will probably rebuilt sometime in the future when I got some time on my hands. Cheers
MFejsa |
Feb 3 2021, 11:02 AM
Appreciate the advise. Will be scrapping this engine as I dont know what else is going with it. Will rebuilt it later. CHeers
VaccaRabite |
Feb 3 2021, 11:36 AM
En Garde! Group: Admin Posts: 13,456 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I wonder if its just a Bus motor that someone swapped in at some point to get the car running.
But, hydraulic lifters were a popular if misguided "upgrade" for decades - until the early 2000s. The entire engine need not be scrapped. But pull it and see what you have. Taking the motor out and pulling the heads off is only about a day of work, and you need to do that anyway if you are doing a top end rebuild. Zach |
MFejsa |
Feb 4 2021, 10:42 AM
Hi, ive pulled the engine out and taken one of the heads off. Im not sure if the camshaft is suitable for the hydraulic lifter application. I was planning to strip it down completely and refurb the whole motor some time later after I get a new engine in. Dont want to spend money of top end only find problems with the bottom end.
Lo-Fi Version | Time is now: 2nd June 2024 - 07:52 AM |
