WTB/WTT: Steer Shaft |
914werke |
Feb 2 2021, 04:47 PM
"I got blisters on me fingers" Group: Members Posts: 10,157 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
screenguy914 |
Feb 2 2021, 04:53 PM
Member Group: Members Posts: 249 Joined: 6-July 09 From: So. Cal Member No.: 10,540 Region Association: Southern California |
Would a 911 steering shaft fit?
KevinW |
Feb 2 2021, 05:22 PM
Newbie Group: Members Posts: 42 Joined: 25-May 15 From: Winona, Minnesota Member No.: 18,761 Region Association: Upper MidWest |
If it is for a 914/4 I have a few.
Kevin |
914werke |
Feb 2 2021, 06:21 PM
mepstein |
Feb 2 2021, 06:30 PM
914-6 GT in waiting Group: Members Posts: 19,325 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
If I recall, Rory had an issue with his car because there are different size shafts for early and late. I think it’s because the early cars used longer u joints. I think the 911 one is different as well.
@Rgalla9146 |
914forme |
Feb 2 2021, 07:43 PM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
I have one if you need it, reality most likely 3-4 of them.
PM me if you ned it it will be cheap. |
bdstone914 |
Feb 2 2021, 09:34 PM
bdstone914 Group: Members Posts: 4,542 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
[quote name='914werke' date='Feb 2 2021, 04:47 PM' post='2887808']
(IMG:style_emoticons/default/smile.gif) Looks like this ] Early 911 shafts are 1mm larger in diameter. Even amoung 914 there are different lenght. Shafts. You may need to extend the crosscut for the the bolt to prevent binding of the shaft. After installing turn the wheel to make sure there is no binding. |
rgalla9146 |
Feb 3 2021, 09:39 AM
Advanced Member Group: Members Posts: 4,570 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
If I recall, Rory had an issue with his car because there are different size shafts for early and late. I think it’s because the early cars used longer u joints. I think the 911 one is different as well. @Rgalla9146 Let me check what I have. What I remember is that there are two lengths for 4 cyl. cars. The shorter one is suitable for 6 cyl. cars. Please comment if know better. Mark....on your toes as usual ! |
mepstein |
Feb 3 2021, 09:43 AM
If I recall, Rory had an issue with his car because there are different size shafts for early and late. I think it’s because the early cars used longer u joints. I think the 911 one is different as well. @Rgalla9146 Let me check what I have. What I remember is that there are two lengths for 4 cyl. cars. The shorter one is suitable for 6 cyl. cars. Please comment if know better. Mark....on your toes as usual ! If the early fours and sixes used the longer U joints then the shorter rod makes sense. I just didn't piece it together until now. |
914LIVE |
Feb 3 2021, 02:17 PM
Newbie Group: Members Posts: 10 Joined: 29-June 10 From: Portland, Oregon. Member No.: 11,890 Region Association: None |
Good afternoon. I have one or two. One from the concours car. Grand total of $ 0.00 plus shipping. Thank you, Tomas. ================================= |
rgalla9146 |
Feb 3 2021, 07:29 PM
[quote name='bdstone914' date='Feb 2 2021, 10:34 PM' post='2887894']
[quote name='914werke' date='Feb 2 2021, 04:47 PM' post='2887808'] (IMG:style_emoticons/default/smile.gif) Looks like this ] Early 911 shafts are 1mm larger in diameter. Even amoung 914 there are different lenght. Shafts. You may need to extend the crosscut for the the bolt to prevent binding of the shaft. After installing turn the wheel to make sure there is no binding. [/quote] (IMG:style_emoticons/default/agree.gif) When first driving my GT car I had a bind in each rotation of the steering wheel. After plenty of disassembly of the newly assembled car I found the issue. There are two different length steering shafts, the longer one is 358mm and as I recall the shorter is ~352mm. Another difference is the shorter one has the recesses for the cinch bolt 'in line' On the longer shaft they are not in line I removed the long one, installed the shorter one...problem solved. The issue could have been from one, the other, or both differences. A load was bearing on the universal joints. Attached thumbnail(s) |
914LIVE |
Feb 4 2021, 06:50 PM
So far I have located one. One from the concours car. It measures 33 inches on the dot. Waiting for your reply. Thank you, Tomas. ================================== |
rgalla9146 |
Feb 5 2021, 05:55 AM
================================= So far I have located one. One from the concours car. It measures 33 inches on the dot. Waiting for your reply. Thank you, Tomas. ================================== Tomas I'm certain there is no part in the steering that is 33 inches long. please check your work .....typo ? |
914LIVE |
Feb 6 2021, 06:48 PM
Correction : 31 inches long. Thank you. ================================= ================================= So far I have located one. One from the concours car. It measures 33 inches on the dot. Waiting for your reply. Thank you, Tomas. ================================== Tomas I'm certain there is no part in the steering that is 33 inches long. please check your work .....typo ? |
rgalla9146 |
Feb 7 2021, 07:57 PM
OR 31"
Lo-Fi Version | Time is now: 16th June 2024 - 03:56 PM |
