motorvated |
Member ![]() ![]() Group: Members Posts: 282 Joined: 13-February 13 From: Colorado Member No.: 15,519 Region Association: Rocky Mountains ![]() |
Time to re-grease my CV joints and I have a tub of Lucas Red "N" Tacky Grease that says it is a high quality lithium complex grease fortified with extreme pressure (EP) lubricant additives that inhibit rust, corrosion, and oxidation setting it apart from similar greases. It is rated as NLGI #2 and GC-LB, although I haven't yet searched out those specifications. Made in the USA. I'm using this on the wheel bearings of my trailer and was wondering if it also could be used for the CV Joints on the 914. Was wondering if anyone has used this grease for this application successfully, and/or if there is another grease that may come highly recommended from experienced users. Photo of the container below.
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,011 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
I like Red and Tacky on my trailer too
but only use the Swepco 101 moly grease on CV's |
BillJ |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,310 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None ![]() ![]() |
+1 for Swepco
motorvated |
iankarr |
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,564 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region ![]() ![]() |
Yep. You want a grease with molybdenum disulfide. Just don't ask me to pronounce that (IMG:style_emoticons/default/wink.gif).
Swepco 101. or Liqui Moly 2003. the nice thing about the LM grease is that one tube is almost exactly what's recommended per joint so there's less guesswork with greasy fingers. Here's a link. https://www.amazon.com/Liqui-Moly-2003-Long...4465&sr=8-1 And here's a video I recently made of repacking the CVs... https://youtu.be/F-5Xpug52Qw |
BillJ |
The Red N Tacky is impressive though being upside down like that and not dripping out. (IMG:style_emoticons/default/smile.gif)
motorvated |
The Red N Tacky is impressive though being upside down like that and not dripping out. (IMG:style_emoticons/default/smile.gif) I was surprised to see the photo displaying upside down, as it looked correct in the preview, but not in the post. Weird! |
bkrantz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,436 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains ![]() ![]() |
Yep. You want a grease with molybdenum disulfide. Just don't ask me to pronounce that (IMG:style_emoticons/default/wink.gif). Swepco 101. or Liqui Moly 2003. the nice thing about the LM grease is that one tube is almost exactly what's recommended per joint so there's less guesswork with greasy fingers. Here's a link. https://www.amazon.com/Liqui-Moly-2003-Long...4465&sr=8-1 And here's a video I recently made of repacking the CVs... https://youtu.be/F-5Xpug52Qw As the old mining company bumper sticker said, "Moly makes your tool harder" |
SKL1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,711 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest ![]() ![]() |
Yep. You want a grease with molybdenum disulfide. Just don't ask me to pronounce that (IMG:style_emoticons/default/wink.gif). Swepco 101. or Liqui Moly 2003. the nice thing about the LM grease is that one tube is almost exactly what's recommended per joint so there's less guesswork with greasy fingers. Here's a link. https://www.amazon.com/Liqui-Moly-2003-Long...4465&sr=8-1 And here's a video I recently made of repacking the CVs... https://youtu.be/F-5Xpug52Qw Great info! Another project while I wait for my heads to come back, getting a loose valve guide fixed! |
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,830 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
I prefer Swepco, but I’ve used Sta Lube CV joint grease which is easy to find locally
slivel |
Old car....... older driver ![]() ![]() ![]() Group: Members Posts: 532 Joined: 10-July 04 From: San Diego Member No.: 2,332 Region Association: Southern California ![]() |
I went with a recommendation from the off-road guys - 50-50 mix of Swepco Moly and BelRay. Been using it for years. No failures so I guess it works. I do periodic CV maintenance, cleaning and repacking.
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
90quattrocoupe |
Member ![]() ![]() Group: Members Posts: 208 Joined: 4-November 16 From: Long Beach, CA. Member No.: 20,561 Region Association: Southern California ![]() |
Lo-Fi Version | Time is now: 11th July 2025 - 05:03 AM |
