WTB 2.0 ECU hanger Bracket, 1976 ECU bracket |
Bucci |
Feb 16 2021, 08:52 AM
Bucci Group: Members Posts: 106 Joined: 11-August 08 From: Carlsbad,Ca Member No.: 9,407 Region Association: Southern California |
Good morning, I’m looking for a 1976 ECU hanger bracket I believe it attaches to the battery tray and holds ECU in place near the firewall, etc.
If one of the members has one please let me know I can blast it and repaint it so condition should not be a big deal. Thanks |
Luke M |
Feb 16 2021, 09:46 AM
Senior Member Group: Members Posts: 1,380 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
I have the 90 degree part of it. LMK.
Attached image(s) |
914Sixer |
Feb 16 2021, 10:34 AM
914 Guru Group: Members Posts: 8,912 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Might have one but frozen in for awhile.
Bucci |
Feb 16 2021, 11:09 AM
Sixer, stay off the highways. Good luck out there let us know if you need us to send anything back like supplies, etc. (IMG:style_emoticons/default/beer3.gif)
Also, is there a secondary bracket that goes with the ECU bracket.? Thanks Might have one but frozen in for awhile. |
bdstone914 |
Feb 16 2021, 03:00 PM
bdstone914 Group: Members Posts: 4,542 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Sixer, stay off the highways. Good luck out there let us know if you need us to send anything back like supplies, etc. (IMG:style_emoticons/default/beer3.gif) Also, is there a secondary bracket that goes with the ECU bracket.? Thanks Might have one but frozen in for awhile. The 76 had the bigger bracket welded to the battery tray. Are there nuts welded to the battery tray? I think i still have one cut from a 76 car. Or you can use the earlier bracket. |
frostyf |
Feb 16 2021, 05:24 PM
Member Group: Members Posts: 154 Joined: 27-March 14 From: VA 23455 Member No.: 17,168 Region Association: MidAtlantic Region |
Sixer, stay off the highways. Good luck out there let us know if you need us to send anything back like supplies, etc. (IMG:style_emoticons/default/beer3.gif) Also, is there a secondary bracket that goes with the ECU bracket.? Thanks Might have one but frozen in for awhile. The 76 had the bigger bracket welded to the battery tray. Are there nuts welded to the battery tray? I think i still have one cut from a 76 car. Or you can use the earlier bracket. Sorry to ask another question in a late car thread, but how did the early bracket attach to the car? Are there supposed to be studs on the firewall or perhaps the battery tray? Does it bolt to both the car and the ECU? Anyone have a picture? |
bdstone914 |
Feb 16 2021, 11:47 PM
Sixer, stay off the highways. Good luck out there let us know if you need us to send anything back like supplies, etc. (IMG:style_emoticons/default/beer3.gif) Also, is there a secondary bracket that goes with the ECU bracket.? Thanks Might have one but frozen in for awhile. The 76 had the bigger bracket welded to the battery tray. Are there nuts welded to the battery tray? I think i still have one cut from a 76 car. Or you can use the earlier bracket. Sorry to ask another question in a late car thread, but how did the early bracket attach to the car? Are there supposed to be studs on the firewall or perhaps the battery tray? Does it bolt to both the car and the ECU? Anyone have a picture? @frostyf Pre 75 cars had nuts welded to the front edhe of the battery tray. The bracket attached to those nuts. Many replacement battery trays do not have the nuts. |
frostyf |
Feb 17 2021, 08:20 AM
Sixer, stay off the highways. Good luck out there let us know if you need us to send anything back like supplies, etc. (IMG:style_emoticons/default/beer3.gif) Also, is there a secondary bracket that goes with the ECU bracket.? Thanks Might have one but frozen in for awhile. The 76 had the bigger bracket welded to the battery tray. Are there nuts welded to the battery tray? I think i still have one cut from a 76 car. Or you can use the earlier bracket. Sorry to ask another question in a late car thread, but how did the early bracket attach to the car? Are there supposed to be studs on the firewall or perhaps the battery tray? Does it bolt to both the car and the ECU? Anyone have a picture? @frostyf Pre 75 cars had nuts welded to the front edhe of the battery tray. The bracket attached to those nuts. Many replacement battery trays do not have the nuts. Thanks for that info on the nuts, believe mine are missing! |
rgb91424 |
Feb 17 2021, 06:03 PM
Newbie Group: Members Posts: 20 Joined: 12-March 06 From: Kingman Az Member No.: 5,709 |
Bucci |
Feb 17 2021, 06:50 PM
Lo-Fi Version | Time is now: 17th June 2024 - 04:33 AM |
