1974 2.0 FI, Fuel injectors |
Ebradley |
Feb 28 2021, 11:45 AM
Newbie Group: Members Posts: 45 Joined: 16-April 20 From: California Member No.: 24,142 Region Association: Southern California |
Hi
I have a 1974 2.0 all original in excellent shape. 1 of my injectors is leaking. I think it’s from the rubber connector to fuel rail. Are these easy to take off? Should I unplug the electrical component? Thanks for all your advice Enrique |
ndfrigi |
Feb 28 2021, 12:26 PM
Advanced Member Group: Members Posts: 2,933 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
Mark Henry |
Feb 28 2021, 12:27 PM
Carefully cut the ferrule off and remove the hose. Then a new hose elbow can be used with proper FI connectors.
Ebradley |
Feb 28 2021, 01:52 PM
Should I change all rubber parts as well? Thanks fellas for the advice
Mark Henry |
Feb 28 2021, 01:56 PM
Ebradley |
Feb 28 2021, 03:20 PM
Should I change all rubber parts as well? Thanks fellas for the advice Unknown history I'd replace every fuel hose on the car with SAE 30R9 or higher. This is a hose that is FI and E-15 rated. Edit plus use the correct FI hose clamps. Thanks. I’m the 3rd owner and previous owner replaces all fuel lines, etc. I was wondering if I need to change out the fuel injector rubber seals if I take it out |
pete000 |
Feb 28 2021, 03:40 PM
Senior Member Group: Members Posts: 1,885 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States |
Send them to RC injectors in Torrance CA and have them cleaned and rebuilt. It's well worth it, not too expensive and you will get full dyno test results for before and after.
Ebradley |
Feb 28 2021, 04:07 PM
Bleyseng |
Feb 28 2021, 04:48 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
I change the fuel lines every 3-4 years on my cars. Including the injector little hose pieces. Its chesp and takes a couple hrs along with cleaning parts. Change the injector nose O ring too but not the big O ring
Ebradley |
Mar 1 2021, 07:51 AM
Lo-Fi Version | Time is now: 7th June 2024 - 06:41 AM |
