Curbandgutter |
Senior Member ![]() ![]() ![]() Group: Members Posts: 564 Joined: 8-March 13 From: Murrieta CA Member No.: 15,637 Region Association: Southern California ![]() ![]() |
Lowered 914's.........how low can you go and how much uptravel do you have left?
This is mine with 1" of uptravel left. and 4" of ground clearance Let's see your pics. ![]() |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,641 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
stock suspension points in the chassis ?
lowering a car too far will blow out your shocks when you hit a bump or pot hole I found around 5 inches to be the best ride height... but I have custom length shocks for a lowered race car.... stock shocks would need more |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
johnhora |
Senior Member ![]() ![]() ![]() Group: Members Posts: 867 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None ![]() ![]() |
To keep travel
Front...Raised front spindles Rear....Tangerine Racing raised rear shock tower |
brant |
Curbandgutter |
Hey guys, good information, but I wanted to see how low you guys are going and how much shock travel you have left.
yeahmag |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,424 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California ![]() ![]() |
I'm VERY low to get enough negative camber in the rear. Here are my measurements:
8.0" free spring length 6.5” static spring height 17.5” top of perch to centerline of shock bolt. 13.75” shock bottomed out. Top of perch to centerline of shock bolt. 3.75” total travel from static 5.25 total spring travel (static compression + total travel) 1” clearance to frame 1” bump stop height (may not be actually doing anything) I do run relatively high rear spring rate to try and keep from bottoming out though. |
Curbandgutter |
I'm VERY low to get enough negative camber in the rear. Here are my measurements: 8.0" free spring length 6.5” static spring height 17.5” top of perch to centerline of shock bolt. 13.75” shock bottomed out. Top of perch to centerline of shock bolt. 3.75” total travel from static 5.25 total spring travel (static compression + total travel) 1” clearance to frame 1” bump stop height (may not be actually doing anything) I do run relatively high rear spring rate to try and keep from bottoming out though. That's what I'm looking for. (IMG:style_emoticons/default/smile.gif) So you have 3.75 of up travel? And you have 1" clearance in the static before it hits the frame? In the static position, what is the distance from ground to the pinch welds along the front and back of the longs? Thanks for your input. I'm trying to understand something on my build and this information really helps. |
yeahmag |
Right now with the 550lb springs I'm at 4.5" at the pinch weld.
Curbandgutter |
campbellcj |
I can't Re Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,550 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California ![]() ![]() |
I'll measure mine this weekend. Has raised/decambered spindles in front and stock geometry in back; similarly I run 300-350lb rear springs and don't have issues with bottoming (often), custom valved bilsteins.
slivel |
Old car....... older driver ![]() ![]() ![]() Group: Members Posts: 510 Joined: 10-July 04 From: San Diego Member No.: 2,332 Region Association: Southern California ![]() |
yeahmag |
Longacre 52-78318 Mini Chassis Height Checker https://www.amazon.com/dp/B005S0YP2Q/ref=cm...=UTF8&psc=1
Curbandgutter |
Longacre 52-78318 Mini Chassis Height Checker https://www.amazon.com/dp/B005S0YP2Q/ref=cm...=UTF8&psc=1 Damn it......why did you have to show me this tool........my hands are shaking......must buy (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) |
Stltri |
Member ![]() ![]() Group: Members Posts: 70 Joined: 13-April 15 From: SoCal Member No.: 18,622 Region Association: None ![]() |
Longacre 52-78318 Mini Chassis Height Checker https://www.amazon.com/dp/B005S0YP2Q/ref=cm...=UTF8&psc=1 Cool tool!! But wouldn’t a regular tape measure give me the same measurements? |
yeahmag |
Try it. You'll see. It's not easy...
Curbandgutter |
Shivers |
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,453 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California ![]() |
Curbandgutter |
Lowered 914's.........how low can you go and how much uptravel do you have left? This is mine with 1" of uptravel left. and 4" of ground clearance Let's see your pics. ![]() Wow, that looks tough. Might want to leave room for snails and such. Great build. (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) DAMN THE SNAILS!! |
Lo-Fi Version | Time is now: 17th June 2024 - 12:36 PM |
