Wafers - Tumblers - Springs, Who sells parts to locks? |
Niklas |
Mar 7 2021, 03:49 AM
Porsche 914 Sweden Group: Members Posts: 366 Joined: 20-June 09 From: Sweden - Skivarp Member No.: 10,488 Region Association: Scandinavia |
Who sells tumblers ( Wafers ) and springs now?
Niklas |
914Sixer |
Mar 7 2021, 06:57 AM
914 Guru Group: Members Posts: 8,906 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
914Rubber was going to make them but not sure IF i ever happened.
ConeDodger |
Mar 7 2021, 07:07 AM
Apex killer! Group: Members Posts: 23,614 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
bdstone914 |
Mar 7 2021, 08:43 AM
bdstone914 Group: Members Posts: 4,537 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
pete000 |
Mar 7 2021, 09:27 AM
Senior Member Group: Members Posts: 1,885 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States |
Do a search on the Samba for Gabriel Locks, he rebuilds VW locks.
iankarr |
Mar 7 2021, 09:54 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,481 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Also Curt Curtis on FB
Mikey914 |
Mar 7 2021, 10:08 AM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Yes these are on the list. I have not seen new. The problem is that if they are used they can be worn unevenly.
You may have to go through a few to match your ignition key to the door. Are new available now and how much are they? |
bbrock |
Mar 7 2021, 10:22 AM
I bought new wafers and springs from member @tweet a few years ago but he hasn't been active here for a couple years. He was getting new wafers from someplace though so they must be available.
bdstone914 |
Mar 7 2021, 10:41 AM
bdstone914 |
Mar 7 2021, 10:44 AM
Who sells tumblers ( Wafers ) and springs now? @Niklas This looks like the source https://www.easykeys.com/1831_ESP_Cam_Lock_...RK-30-0000.aspx |
willieg |
Mar 7 2021, 11:07 AM
Member Group: Members Posts: 132 Joined: 13-August 18 From: Pleasant Hill Member No.: 22,389 Region Association: Northern California |
I have had good response from keys4classics.com. They are an Aussie company.
bdstone914 |
Mar 7 2021, 11:57 AM
Yes these are on the list. I have not seen new. The problem is that if they are used they can be worn unevenly. You may have to go through a few to match your ignition key to the door. Are new available now and how much are they? Not that much. Maybe buy the 400 kit and repack. https://www.easykeys.com/1831_ESP_Cam_Lock_...RK-30-0000.aspx @Mikey914 |
TheCabinetmaker |
Mar 7 2021, 02:41 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Those are not the same. They are made for cam style locks. They are not the same size. I've checked all those vendors and they state that they will not fit automotive locks.
Mikey914 |
Mar 7 2021, 05:31 PM
I'm totally down with buying in bulk and reselling in bit size pieces to make stuff reasonable. Just gotta do my homework to make sure its correct.
TheCabinetmaker |
Mar 7 2021, 06:03 PM
Mikey914 |
Mar 7 2021, 07:10 PM
Which is why we were looking to make them.
The tooling is not cheap. |
JeffBowlsby |
Mar 7 2021, 07:47 PM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
914Sixer |
Mar 8 2021, 06:26 AM
Lets be clear, VW wafers and 914/911 wafers are COMPLETELY different thickness. Not interchangeable.
TheCabinetmaker |
Mar 8 2021, 06:31 AM
Mark nailed it. Vw wafers will NOT fit!
Niklas |
Mar 9 2021, 04:31 AM
Yes these are on the list. I have not seen new. The problem is that if they are used they can be worn unevenly. You may have to go through a few to match your ignition key to the door. Are new available now and how much are they? Not that much. Maybe buy the 400 kit and repack. https://www.easykeys.com/1831_ESP_Cam_Lock_...RK-30-0000.aspx @Mikey914 It says that these does not fit car locks. Niklas |
Lo-Fi Version | Time is now: 10th June 2024 - 07:14 AM |
