pcdarks |
Member ![]() ![]() Group: Members Posts: 80 Joined: 22-June 13 Member No.: 16,037 Region Association: None ![]() |
I found this site that has all of the lights necessary to convert all to LED. The prices look good. For those of you that have done this what Color and Kelvin did you find worked well for the different applications? https://www.superbrightleds.com/vehicle/197...1&year=1972
Brake light Back up light parking light rear turn signal light instrument panel light bulb (What color?) How many? Generator,oil, brake light bulb (color? are they the same as instrument light?) For future reference if this turns out to be productive it might make a good sticky. |
Coondog |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California ![]() ![]() |
That’s all great, but if your not using spokeworksled.com/914-led-solutions
For all your outside 914 lights your just selling yourself short. |
pcdarks |
That’s all great, but if your not using spokeworksled.com/914-led-solutions For all your outside 914 lights your just selling yourself short. For those of us that don't want to pay $50per light but rather $10 for the same effect the site I specified is much better. I converted my 57 Chevy to these kind of lights and they work great. ![]() |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,545 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
I found this site that has all of the lights necessary to convert all to LED. The prices look good. For those of you that have done this what Color and Kelvin did you find worked well for the different applications? https://www.superbrightleds.com/vehicle/197...1&year=1972 Brake light Back up light parking light rear turn signal light instrument panel light bulb (What color?) How many? Generator,oil, brake light bulb (color? are they the same as instrument light?) For future reference if this turns out to be productive it might make a good sticky. @pcparks Do not do the generator light. The charging system will not work. |
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,466 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() |
Couple things:
I have used SuperbriteLED years ago for my dash lights and they are still going strong and are brighter then stock. I use Spokes boards for my brake, reverse, and turn signals. Spokes boards are a LOT brighter then stock and I want my little car to be seen. I have no doubt that the lights at SuperBrite will work, but they will not work as well as Spoke’s system. Also, when you buy from Spoke you are buying and supporting a member of this forum who will work with you to make custom stuff for your car, and has helped many of us sort out electrical issues that we could not have solved ourselves. I agree with above, if you go cheap on your external lights it is a false economy. Good luck which ever way you go. Zach |
Lo-Fi Version | Time is now: 17th June 2024 - 09:51 AM |
