Buische |
Newbie ![]() Group: Members Posts: 4 Joined: 20-January 21 From: Peoria IL Member No.: 25,100 Region Association: Upper MidWest ![]() |
I used Dr. Evil's video suite to tear apart and rebuild my 901 transaxle. Super good, but no discussion about what to expect for proper diff case rotation torque without 1-5 gear stack installed. I pulled the diff and put it in a plastic bag, cleaned the case, and put new seals in. I did not think to check when disassembling.
Diff is open type, side gears spin fine inside diff case. But when I twist both hubs in the same directlon, it takes a lot of effort. I'm guess-timating 30 ft-lb. I don't think this makes sense, but I don't actually know. I am concerned that a previous owner installed the diff wrong. But, the bearings don't have damage that I can see, so I don't have other evidence pointing to incorrect build. Any advice on how to tell if appropriate drag for bearings? Thanks |
stownsen914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 916 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None ![]() |
I don't have the spec in front of me, but 30 ft lb is too high for sure (assuming it's just the diff in there, no pinion or mainshaft). It's usually measured in inch-lb (with only the diff carrier installed, no pinion or mainshaft). I recall for a 915 it's different depending on which brand of bearing you use, so it may be similar for the 901/914. If too tight, you remove shims from the diff carrier.
Edit - if you have the trans fully assembled including pinion + mainshaft assemblies, 30 ft-lb may be about right, though I've not measured it before to be honest. |
mgphoto |
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California ![]() |
Buische |
Very helpful info. Thanks.
Buische |
I don't have the spec in front of me, but 30 ft lb is too high for sure (assuming it's just the diff in there, no pinion or mainshaft). It's usually measured in inch-lb (with only the diff carrier installed, no pinion or mainshaft). I recall for a 915 it's different depending on which brand of bearing you use, so it may be similar for the 901/914. If too tight, you remove shims from the diff carrier. Edit - if you have the trans fully assembled including pinion + mainshaft assemblies, 30 ft-lb may be about right, though I've not measured it before to be honest. I initially had the 1-5 gearset and pinion installed, but took those out to be sure it wasn't due to interference with the pinion. There was some gray area in selecting intermediate plate gasket thickness, so wanted to be sure that was not a factor. |
Buische |
Good news. Went out and put my clicker torque wrench on it, and a short bar across two bolts on the other side. Diff turned with just the weight of the torque wrench, so I think it's OK. The calibration on my hand and arm torque wrench apparently is way out of spec.
Thanks for the info, it helped me make what I think is a good call to continue the build. |
Lo-Fi Version | Time is now: 17th June 2024 - 10:16 AM |
