Another Relay Question, Seems like my board is a little different than others |
stickyfingers |
Mar 16 2021, 11:58 AM
Member Group: Members Posts: 168 Joined: 19-February 21 From: Toronto Member No.: 25,223 Region Association: Canada |
So I as I am fixing some electrical challenges I came across my relay board under the dash. See below:
I have circled a section in Blue. There is a connection for a relay however the PO has put electrical tape on it - assuming he didn't want anything plugged into that. What is that relay used for and why would the PO not put one in there? Hoping someone can shed some light on what that relay would be used for. Thank you! |
ClayPerrine |
Mar 16 2021, 12:00 PM
Life's been good to me so far..... Group: Admin Posts: 15,520 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Hard to tell without knowing the color of the wires going into the relay socket.
BTW. This is the fuse box. The relay board is located in the left side of the engine compartment. Clay |
stickyfingers |
Mar 16 2021, 12:24 PM
Hard to tell without knowing the color of the wires going into the relay socket. BTW. This is the fuse box. The relay board is located in the left side of the engine compartment. Clay Sorry about the confusion - I meant the fuse panel (backside of it). Here is the picture of 3 wires going into it: 2 are white with a brown stripe and 1 red wire. |
ClayPerrine |
Mar 16 2021, 01:12 PM
Hard to tell without knowing the color of the wires going into the relay socket. BTW. This is the fuse box. The relay board is located in the left side of the engine compartment. Clay Sorry about the confusion - I meant the fuse panel (backside of it). Here is the picture of 3 wires going into it: 2 are white with a brown stripe and 1 red wire. That is not a relay socket. It is for the key buzzer. The buzzer was built in the same can as the round relays. But if you plug a relay in there, it will blow a fuse. Hope that helps. Clay |
stickyfingers |
Mar 16 2021, 01:14 PM
Ah ok. Should I get a buzzer to put in there or just more of a nuisance?
ClayPerrine |
Mar 16 2021, 01:15 PM
stickyfingers |
Mar 16 2021, 01:43 PM
Good to know. Thx Clay.
Lo-Fi Version | Time is now: 10th June 2024 - 02:30 AM |
