Have Red key want black as well, replacement key |
swb911s |
Mar 16 2021, 05:48 PM
Newbie Group: Members Posts: 4 Joined: 1-March 21 From: eugene oregon Member No.: 25,278 Region Association: None |
Need black key have red key for car... How do I do this and who does it?
VegasRacer |
Mar 16 2021, 06:00 PM
ELVIRA Group: Benefactors Posts: 8,523 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None |
About twenty bucks on eBay.
914_7T3 |
Mar 16 2021, 06:01 PM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,853 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
Buy it here and take it to be cut from the red one at a locksmith.
https://www.aasesales.com/products/h5f-b52-20i-101724 This is not a valet key and will open frunk handle, glove box and rear trunk. |
bbrock |
Mar 16 2021, 06:43 PM
You can also get black after market blanks that are wide at the bottom and narrow at the top (opposite of the genuine keys) and don't have PORSCHE stamped on them. They are about $5. Just search for 'Porsche key blank' on ebay and you'll find plenty of options for either. I have both and they work the same. Most local locksmiths will have blanks that work like the black key but are all metal so look quite a bit different. Depends on how cheap you are or how authentic you want to be.
My locksmith cut a master blank from the key code for me that is just cut on one side so it doesn't operate, but will always have a fresh, unworn profile to use to cut additional keys. |
98101 |
Mar 16 2021, 11:16 PM
Michael in Seattle Group: Members Posts: 373 Joined: 7-October 17 From: Seattle, WA Member No.: 21,495 Region Association: Pacific Northwest |
I found black blanks at 914Rubber for $15 + shipping. Aftermarket, I think. Any reason not to use these?
VegasRacer |
Mar 17 2021, 12:01 AM
Attached image(s) |
Mikey914 |
Mar 17 2021, 12:07 PM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
BENBRO02 |
Mar 17 2021, 12:09 PM
Member Group: Members Posts: 481 Joined: 6-March 15 From: Nokesville, Virginia Member No.: 18,493 Region Association: MidAtlantic Region |
I’ve heard that some locksmiths won’t cut a steel key because it’s harder and damages their keycutters. I’ve also heard that the steel keys wear the lock tumblers out faster. Not sure if these are facts or fiction. I bought one and had it cut. |
VegasRacer |
Mar 17 2021, 04:31 PM
bbrock |
Mar 17 2021, 07:55 PM
I’ve heard that some locksmiths won’t cut a steel key I had to call five before I found someone to do the job. Well I've learned something. This got me curious so I inspected the keys I have. Here are most of them. From left to right is: master blank cut only on one side so it always has a sharp profile to cut other keys from, key cut from blank typically found at your local locksmith, two after market keys from different sources, and finally, the OEM key. You can tell that the keys from the local locksmith blanks are plated (nickel?) brass blanks by looking at the cut edges. The rest of the keys are silver all the way through, BUT the aftermarket keys are magnetic and the OEM key is NOT. I'm not sure why the OEM key is silver all the way through because I have an old OEM key that has brass show over much of the surface where the plating has worn off. My locksmith didn't complain about cutting any of them but it appears you get what you pay for. Looks like for function, OEM and local locksmith blanks might be the better bet for a soft metal key. |
Lo-Fi Version | Time is now: 2nd June 2024 - 04:22 AM |
