> Battery recommendation, Need a new pattery
robkammer
post Mar 18 2021, 05:33 AM
Robbo
Need to order a battery today for my 74. My typical go-to is a Napa battery. I've had good luck with them in many vehicles and boats. I'm open to a gel battery if that's best for a 914. Any recommendations? The car will always be garaged so rainwater will be pretty rare.
Replies(1 - 19)
ClayPerrine
post Mar 18 2021, 06:25 AM
QUOTE(robkammer @ Mar 18 2021, 06:33 AM) *
I have had excellent service from Optima batteries. I have one in every car, and all the same size. I did that on purpose so I could swap them around if I had an issue.
The gel cell is great for keeping the hell hole intact too.
Clay
930cabman
post Mar 18 2021, 06:47 AM
QUOTE(ClayPerrine @ Mar 18 2021, 06:25 AM) *
Clay
+1 with Optima. I recently replaced on in our 356 coupe, it had done the job for 14 years.
Sycolyst
post Mar 18 2021, 07:31 AM
Just ordered a NAPA Legend for $129. Also noticed you were from Vermilion, I'm located in Berlin Heights. Small world.
ericoneal
post Mar 18 2021, 09:39 AM
I have an Optima battery going on 10 years now. Heard they moved the plant and quality is not what it used to be, so not sure if I will get another one.
yellowporky
post Mar 18 2021, 10:19 AM
I installed a D36
It was a little tall so I had to reroute the positive battery cable a little bitAttached Image
g911
post Jul 5 2021, 01:28 PM
I am also looking at a replacement battery. Is the optima 34R still the preferred battery? Does it have a base similar to the d36 pictured above to clamp in the stock location? I thought I read somewhere that an additional base part “ gm78?” was required to use the stock hold down. Words of wisdom appreciated.
StarBear
post Jul 5 2021, 02:35 PM
Just put in another Optima Red 34R. Have to trim the base sides a bit; comes with hold down adapter. Last one lasted only 2.5+ years but must be a recall unit as FLAPS replaced it 100% without question. Keep your paperwork. Otherwise, Napa Legend for reasonable price options.
g911
post Jul 5 2021, 03:00 PM
Thanks for the quick response. Will be putting it on my to do list.
rjames
post Jul 5 2021, 07:12 PM
I'm made of metal
I'll cast my vote for an Odyssey AGM battery. The PC925 is smaller and ~5 lbs lighter than the Optima. I've been really happy with mine so far.
PanelBilly
post Jul 5 2021, 07:17 PM
I use Interstate. There's a distributor near my house and they take good care of me
raynekat
post Jul 6 2021, 01:11 AM
This is the one I put in my car and that I recommend:
I purchased this AGM battery made by XS Power (model D4700) from Jegs onllne.
$279.99 including shipping plus you need a set of $10 terminals.
Specs:
12-Volt
CA: 760
CCA: 668
Ah: 62, 2000W / 3000W
Max Amps: 2900
Reserve Capacity: 110 Minutes
Weight: 42.2 lbs
It fits perfect in the battery tray and the factory hold down works as it should.
rjames
post Jul 6 2021, 10:46 AM
I'm made of metal
QUOTE(raynekat @ Jul 6 2021, 12:11 AM) *
Specs:
12-Volt
CA: 760
CCA: 668
Max Amps: 2900
Weight: 42.2 lbs
Nice that it fits like stock, but that's expensive AND heavy. Yikes.
horizontally-opposed
post Jul 6 2021, 11:42 AM
Specs:
12-Volt
CA: 760
CCA: 668
Max Amps: 2900
Weight: 42.2 lbs
Interesting as you came out of an Anti-Gravity iirc?
I've been looking at Anti-Gravity, Odyssey 680 or 925, and Voltphreaks—two suppliers that are expensive (!) and one that seems reasonable for what you get in terms of weight savings. I'm a longtime Optima customer, and thankful as the 2-3 that have been in the car since 1991 probably saved its hell hole years ago.
No pressing need, but very interested in offsetting some of my 2.2-liter engine's added weight. If the engine added ~120lbs, a battery that's 20-30lbs lighter is extremely appealing.
oakdalecurtis
post Jul 6 2021, 11:48 AM
Oakdalecurtis
Love my Optima, but hated attaching the special trickle charger every time I came home. These chargers will triple the life of an Optima battery, and keep the battery topped off if I don't drive my teener for a few weeks spell. I hated always having to open the engine bay to connect, so check out my solution from this previous post. Just plugs in under the wheel well, easy to install.....
http://www.914world.com/bbs2/index.php?sho...6&hl=optima
post Jul 6 2021, 12:09 PM
Resident German
QUOTE(oakdalecurtis @ Jul 6 2021, 10:48 AM) *
I had the same optima (red top) for 15+ years and i have periods where the car sits for months without running.
I had to trickle charge it *once* in all those years because it wouldn't turn over after sitting for many months. Once.
post Jul 6 2021, 01:04 PM
QUOTE(SirAndy @ Jul 6 2021, 11:09 AM) *
Same. 30 years, three Optimas. Not one was ever on a trickle charger, and all have gone at least 10 years. Car sat for weeks and even months at a time.
If I go for a lightweight battery, it'll get a cut-off switch at the battery.
dr914@autoatlanta.com
post Jul 6 2021, 01:12 PM
series 42 bosch
QUOTE(robkammer @ Mar 18 2021, 04:33 AM) *
euro911
post Jul 6 2021, 02:20 PM
I recommend the Odyssey PC-925 too. I had one sit idle for approximately 3 years without a charge on it (mid 2015 ~ mid 2018). In 2018, I charged it with a smart AGM charger for a day and it fired up my 9.5 C/R 2056 just fine. I was so impressed, that I purchased another one for another P-car in 2019.
They're a little smaller than a group 34 battery, but I wouldn't let the small size fool you. Also due to the smaller dimensions, you'd have to modify the restraining method - easy modification though.
They cost around $200. these days.
JamesM
post Jul 7 2021, 01:32 PM
QUOTE(euro911 @ Jul 6 2021, 12:20 PM) *
Only batteries I run in 914s anymore, have cars with both the 680 and the 925, either is fine but for most cases think i prefer the 925.
Get a mount (with or without cutoff switch) from Rennline and dont look back...
https://www.rennline.com/Battery-Mount-Kits/products/169/
- Lo-Fi Version Time is now: 2nd April 2026 - 03:07 PM
