Frunk Hinge Bracket Split? |
bkrantz |
Mar 25 2021, 07:41 PM
914 Guru Group: Members Posts: 7,804 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
Is this split in the corner of the bracket normal, or should it be continuous (either the original stamping or welded)?
Attached thumbnail(s) |
Robarabian |
Mar 25 2021, 08:09 PM
914 A Roo Group: Members Posts: 592 Joined: 11-February 19 From: Simi Valley, Kalifornia Member No.: 22,865 Region Association: Southern California |
Although I have not looked at mine, one would think it isn't a big deal. There is not that much spring pressure or force on these. It should be fine.
mepstein |
Mar 25 2021, 09:03 PM
914-6 GT in waiting Group: Members Posts: 19,316 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Looks like someone tried welding it already.
wonkipop |
Mar 26 2021, 02:24 AM
Advanced Member Group: Members Posts: 4,403 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
no thats right.
i looked at mine which is original. the two folded bits of steel in the stamping meet right there. no weld as far as i can tell. it looks a little cleaner on mine but its where there is a join between two separate bits of metal as it folds up. i can try and photograph mine if you want as its all factory still. |
914Sixer |
Mar 26 2021, 06:43 AM
914 Guru Group: Members Posts: 8,906 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Since the hinge has considerable weight on it, get another one.
mgarrison |
Mar 26 2021, 08:12 AM
Member Group: Members Posts: 356 Joined: 14-February 20 From: Chandler, AZ Member No.: 23,922 Region Association: Southwest Region |
Appears to be that way from the factory. Both hinges off my '74 look the same... (IMG:style_emoticons/default/idea.gif)
mgarrison |
Mar 26 2021, 08:16 AM
914Sixer |
Mar 26 2021, 08:59 AM
Boy, no quality control on the parts for sure.
wonkipop |
Mar 26 2021, 04:01 PM
its not pretty. but it is a complex pressing. double fold for spring retainer. and its thick metal mercedes benz style, not like present day options of tissue paper tin or plastic.
bkrantz |
Mar 26 2021, 08:55 PM
Thanks, guys. If I had noticed before painting, I would have welded it. Now I am not sure if I want to back to the paint shop.
Lo-Fi Version | Time is now: 10th June 2024 - 07:11 AM |
