bkrantz
Mar 25 2021, 07:41 PM
Is this split in the corner of the bracket normal, or should it be continuous (either the original stamping or welded)?
Robarabian
Mar 25 2021, 08:09 PM
Although I have not looked at mine, one would think it isn't a big deal. There is not that much spring pressure or force on these. It should be fine.
Mar 25 2021, 09:03 PM
Looks like someone tried welding it already.
wonkipop
Mar 26 2021, 02:24 AM
no thats right.
i looked at mine which is original.
the two folded bits of steel in the stamping meet right there.
no weld as far as i can tell.
it looks a little cleaner on mine but its where there is a join between two separate bits of metal as it folds up.
i can try and photograph mine if you want as its all factory still.
914Sixer
Mar 26 2021, 06:43 AM
Since the hinge has considerable weight on it, get another one.
mgarrison
Mar 26 2021, 08:12 AM
Appears to be that way from the factory. Both hinges off my '74 look the same...
mgarrison
Mar 26 2021, 08:16 AM
Here's a better pic of both frunk hinges:
914Sixer
Mar 26 2021, 08:59 AM
Boy, no quality control on the parts for sure.
wonkipop
Mar 26 2021, 04:01 PM
its not pretty. but it is a complex pressing. double fold for spring retainer. and its thick metal mercedes benz style, not like present day options of tissue paper tin or plastic.
bkrantz
Mar 26 2021, 08:55 PM
Thanks, guys. If I had noticed before painting, I would have welded it. Now I am not sure if I want to back to the paint shop.
