adolimpio |
Art ![]() ![]() Group: Members Posts: 182 Joined: 10-March 10 From: Greenwood SC Member No.: 11,449 Region Association: South East States ![]() ![]() |
Does anyone have a picture of the proper routing of the speedometer cable under the engine?
cary |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest ![]() ![]() |
You don't really want anything hanging down if you can get away with it. Matt @914Rubber had his right e-brake cable ripped off/out on one of his excursions. |
bbrock |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains ![]() ![]() |
Don't know what's proper. But I put it thru the hole in the bar with the provided rubber sleeve. You don't really want anything hanging down if you can get away with it. Matt @914Rubber had his right e-brake cable ripped off/out on one of his excursions. Isn't the hole in the engine bar for the clutch cable? That's the only cable I have with a rubber sleeve in that location. I routed the speedo cable over the top of the bar and zip-tied it to the clutch cable about mid-way between the engine bar and speedometer angle drive to keep it up as high as possible. Don't know what the factory did. |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,545 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
Does anyone have a picture of the proper routing of the speedometer cable under the engine? I have found that if you route it over the axle and use a loop clamp to attach the cable to the 12 o'clock position stud on the trans that it takes up the slack and keeps it away from the heat exchangers. @adolimpio |
cary |
Yes and yes.
Too tired from floorpan blasting yesterday. |
barefoot |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,282 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States ![]() ![]() |
Try this :
adolimpio |
What is shown in the picture is the direction I was headed. You really need the tie wraps to make it neat and I assumed that they were not used originally so I thought there must be a different route.
Thanks to all for your help! |
Lo-Fi Version | Time is now: 17th June 2024 - 01:01 PM |
