Aftermarket Blower-fan, looking for suggestions |
RiqueMar |
Mar 29 2021, 05:43 PM
Enrique Allen Mar Group: Members Posts: 2,169 Joined: 28-August 08 From: San Diego, CA Member No.: 9,478 Region Association: Southern California |
Hi All,
Looking for suggestions on aftermarket blower fans for my 3.6 conversion. Nothing wrong with the stock 914 equipment, but would like to know what members have used to give the system a bit more 'Umph'. Pictures welcome, thanks in advance! |
jim_hoyland |
Mar 29 2021, 05:47 PM
Get that VIN ? Group: Members Posts: 9,314 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I considered modifing 911 footwell fans at one time....
mepstein |
Mar 29 2021, 06:51 PM
914-6 GT in waiting Group: Members Posts: 19,307 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Talk to Jonny who does the electric a/c kits. He supplies a better fan for his kits.
https://www.classicretrofit.com/ |
ClayPerrine |
Mar 30 2021, 10:47 AM
Life's been good to me so far..... Group: Admin Posts: 15,503 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Are you talking about the fresh air fan?
Clay |
DRPHIL914 |
Mar 30 2021, 11:14 AM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
[quote name='RiqueMar' date='Mar 29 2021, 07:43 PM' post='2903951']
Hi All, Looking for suggestions on aftermarket blower fans for my 3.6 conversion. Nothing wrong with the stock 914 equipment, but would like to know what members have used to give the system a bit more 'Umph'. Pictures welcome, if you are talking about the front defrost/fresh air fan, i just rebuilt one using the new URO fan and motor assembly and on high speed its surprising how much air it moves, there is no need to do anything different for this, it moves a lot of air. - and if you want one that has a good resistor pack, i have 2 that are ready to be rebuilt, just need to order the replacment fan/motor, but i have them on my desk ready to install the new fan, i just have to order the new seals, will include a fan to housing seal and upper and lower airbox seal and flapper seal. - PM for details. if you have one that needs to be rebuilt you can send me as a core, i will take $100 off the price for this. Phil, |
RiqueMar |
Mar 30 2021, 01:15 PM
Are you talking about the fresh air fan? Clay Hey Clay, I'm talking about the fan, located in the engine bay, used to push air through the Heat-exchangers. When my engine was in the previous car, it had a system seen in the photo below. I don't remember if it was a good solution or not, and believe I have since lost the fan. |
RiqueMar |
Mar 30 2021, 01:19 PM
if you are talking about the front defrost/fresh air fan, i just rebuilt one using the new URO fan and motor assembly and on high speed its surprising how much air it moves, there is no need to do anything different for this, it moves a lot of air. - and if you want one that has a good resistor pack, i have 2 that are ready to be rebuilt, just need to order the replacment fan/motor, but i have them on my desk ready to install the new fan, i just have to order the new seals, will include a fan to housing seal and upper and lower airbox seal and flapper seal. - PM for details. if you have one that needs to be rebuilt you can send me as a core, i will take $100 off the price for this. Phil, @DRPHIL914 Hi Phil - My mistake for not specifying int he original post. Not looking for the Fresh-air type blower, but rather something for the heating system. Thanks anyway! (IMG:style_emoticons/default/bye1.gif) |
ClayPerrine |
Mar 30 2021, 01:21 PM
That is a common engine compartment fan for a 914/4. They were not used on the sixes.
Lots of them out there. Clay |
DRPHIL914 |
Mar 30 2021, 01:34 PM
if you are talking about the front defrost/fresh air fan, i just rebuilt one using the new URO fan and motor assembly and on high speed its surprising how much air it moves, there is no need to do anything different for this, it moves a lot of air. - and if you want one that has a good resistor pack, i have 2 that are ready to be rebuilt, just need to order the replacment fan/motor, but i have them on my desk ready to install the new fan, i just have to order the new seals, will include a fan to housing seal and upper and lower airbox seal and flapper seal. - PM for details. if you have one that needs to be rebuilt you can send me as a core, i will take $100 off the price for this. Phil, @DRPHIL914 Hi Phil - My mistake for not specifying int he original post. Not looking for the Fresh-air type blower, but rather something for the heating system. Thanks anyway! (IMG:style_emoticons/default/bye1.gif) @RiqueMar hey you might be able to try a bilge fan from a marine supply store, they could be mounted under there in line, but a good stock one should be fine, my rear aux fan for the heat also went bad and i sourced one from a member hear fairly cheap, like Clay said there are a lot of them out there. good luck! |
RiqueMar |
Mar 30 2021, 01:41 PM
hey you might be able to try a bilge fan from a marine supply store, they could be mounted under there in line, but a good stock one should be fine, my rear aux fan for the heat also went bad and i sourced one from a member hear fairly cheap, like Clay said there are a lot of them out there. good luck! @DRPHIL914 You're on to my train-of-thought. Originally, the previous installation had the heater-tube going up and over the engine. To make it look cleaner and supply more air-flow, was thinking to put a blower on each side of the engine, supplying each of the ducts that lead to the cabin, photo below. I wasn't aware the motor in the photo was a stock 914/4 part, shows how much I know. I'll put up an add in the classified section. (IMG:style_emoticons/default/bye1.gif) |
mepstein |
Mar 30 2021, 03:31 PM
Backdate the heat. Looks way cleaner and works great in a 914 with so little cabin volume. - as long as you have good heat exchangers like what Ben makes.
RiqueMar |
Mar 30 2021, 03:41 PM
Backdate the heat. Looks way cleaner and works great in a 914 with so little cabin volume. - as long as you have good heat exchangers like what Ben makes. @mepstein - Nothing like top-off, heat on night-driving. (IMG:style_emoticons/default/shades.gif) |
DRPHIL914 |
Mar 30 2021, 04:40 PM
wow those are great!
Mark Henry |
Mar 30 2021, 05:11 PM
A stock set up gets the best pressure at speed (3K RPM-up).
For an effective booster fan that tied into the stock engine fan you need one way flappers for both sides. The stock VW/914 fan has a flapper built into the plastic end of the fan. If you delete the engine fan circuit I doubt if you find an electric fan that does much better than the engine fan at speed. The electric fan mostly just boosts the air pressure at idle/ low speed. |
mepstein |
Mar 30 2021, 06:41 PM
BB’s are known for mediocre heat. An electric fan won’t help.
But you are in the land of warmth so they might be enough. |
Steve |
Mar 30 2021, 07:59 PM
914 Guru Group: Members Posts: 5,606 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I wonder how well this PMS adapter works with heat exchangers?
https://patrickmotorsports.com/collections/...05-hfs-d225-pms |
RiqueMar |
Mar 30 2021, 08:30 PM
I wonder how well this PMS adapter works with heat exchangers? https://patrickmotorsports.com/collections/...05-hfs-d225-pms Hmmm, hadn't seen that before, interesting solution. Emailing them now. I'm curious about fitment, seems like it would get a little crowded around the engine bay in a 914. |
Lo-Fi Version | Time is now: 2nd June 2024 - 01:31 AM |
