Made a $$$ Mistake, Still Learning The Hard Way |
914Sixer |
Mar 30 2021, 02:49 PM
914 Guru Group: Members Posts: 8,902 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
As you all know, I restore relay boards. Jeff B suggested that I go to using an electrical compound Epoxyseal 9000($40) to seal the relay boards. So, I had 7 boards to seal up. They were all cleaned, tested and ready to go. I had enough to do 4 the old fashion way. All the boards were sealed with silicone in the 4 areas that will leak otherwise and left to dry for two days. So yesterday, I followed the mixing instructions for the Epoxyseal 9000 and set about filling the compound in the back of the boards. Everything looked good when I left them to dry. Went to the warehouse this morning, 3 ruined boards. Best I can tell the epoxy did NOT play well with anything it came into contact with. The epoxy ate the glue off the tape and came out the side of the end and the voltage regulator screws. Guessing it melted the silicone and ran out the voltage regulator plug and the clip lockdown holder. Could not even to begin to peal the tape off the boards. 4 hours, $40 and 3 ruined relay boards
Not sure what you can use to plug up board before pouring the Epoxyseal 9000. Attached image(s) |
Root_Werks |
Mar 30 2021, 03:04 PM
Village Idiot Group: Members Posts: 8,334 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Is that heat damage? I know many two part epoxy products can get pretty warm.
Either way, that sucks. |
bkrantz |
Mar 30 2021, 03:09 PM
914 Guru Group: Members Posts: 7,801 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
I used furniture wax with good success (just did not seal all the places). After the epoxy set, I was able to pick out most of the wax and then flush the remainder with solvent.
Attached thumbnail(s) |
bkrantz |
Sealed holes.
bbrock |
Mar 30 2021, 06:48 PM
Yikes! I used this stuff with silicone to seal holes with no issues.
(IMG:http://www.914world.com/bbs2/uploads/post-20845-1522247648_thumb.jpg) |
JeffBowlsby |
Mar 30 2021, 09:43 PM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Really sorry to hear of this Mark.
"Once an epoxy is fully cured, or a silicone is fully cured, they can be used adjacent to each other without any issues." from here: https://www.jpkummer.com/sites/default/file...nteractions.pdf Did the epoxy otherwise adhere well to the board, and did it just ran out the holes? |
bdstone914 |
Mar 30 2021, 10:30 PM
bdstone914 Group: Members Posts: 4,535 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@914sixer
I do have about 6 stripped boards to send to you. The old way seems fine to me. I do wonder about the effect fo heat ovrmer time on it. |
914Sixer |
Mar 31 2021, 05:58 AM
Ran through every hole. Turned the tape in to rock hard material. Still willing to try one more board to see what I can do. Will do a liquid test to make sure bottom of board is COMPLETELY sealed.Epoxy was rock hard once cured.
rick 918-S |
Mar 31 2021, 06:17 AM
Hey nice rack! -Celette Group: Members Posts: 20,485 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I have wondered about that rubber in a can they advertise on TV. Could make a thick water tite seal
914Sixer |
Mar 31 2021, 08:07 AM
Rick,
Flexseal liquid is what I have been using for years. |
iamchappy |
Mar 31 2021, 08:27 AM
It all happens so fast! Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest |
Flex Seal exactly what struck my mind.
bkrantz |
Mar 31 2021, 09:07 AM
This is what I used for the fill. It remains moderately flexible after curing.
stinkindiesel |
Apr 5 2021, 02:57 PM
Member Group: Members Posts: 184 Joined: 14-June 13 From: Georgetown, TX Member No.: 16,012 Region Association: Southwest Region |
I used spackling compound to seal the holes and Plasti DIP as the sealant. When the Plasti Dip cured, I just washed out the spackling.
Gary |
iankarr |
Apr 5 2021, 08:22 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,480 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Liquid electrical tape works great too...especially if it's just a few pieces in the potting that are missing.
Lo-Fi Version | Time is now: 7th June 2024 - 04:01 AM |
