Cheap 2056? |
Cheap 2056? |
FJ1200 |
Apr 11 2021, 05:34 PM
Member Group: Members Posts: 61 Joined: 26-December 18 From: Harpswell, ME Member No.: 22,751 Region Association: North East States |
Greetings everyone,
What if anything do people know about the Keith Black 96mm pistons from European Motorworks for the 2.0? My 2.0 was built with stock replacement 2.0 Mahle bus pistons and cylinders. I have a local engine builder who I would have trouble actually paying him to bore my stock cylinders to 96mm. The rest of the engine has about 20k miles on it. It has a web 86 cam with matching valve springs, 38x44 valves and twin 44idf (I know too big). It seems like for about $200 it would be a nice little boost to 2056 and a nice bump in compression. I think the whole thing could be accomplished in a weekend (machinist is 1 mile away). Looking for BTDT. The long term goal is 2270, headers, mega squirt etc. This might be a nice boost over my 7.5:1 bust setup. Thoughts? http://www.europeanmotorworks.com/pvw/034-...n+-+Keith+Black |
Bleyseng |
Apr 11 2021, 05:49 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Yes go for it but check your deck ht etc
barefoot |
Apr 12 2021, 06:04 AM
Senior Member Group: Members Posts: 1,279 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
96 mm P & C set I used, happy with them.
https://www.autohausaz.com/pn/03919807596QS...xMaAn7VEALw_wcB |
Shivers |
Apr 12 2021, 07:34 AM
Senior Member Group: Members Posts: 2,410 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Devils advocate: the bump in performance with just that work will not be dramatic. Drive the car, save your money and do the long term goal.
VaccaRabite |
Apr 12 2021, 07:36 AM
En Garde! Group: Admin Posts: 13,456 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
My 2056 has the KB pistons and they have been fantastic. I would not hesitate to use them again.
Build to a target CR, but don't get closer then .040 deck without really measuring to make sure you are not going to start kissing spark plugs/valves. Zach |
rfinegan |
Apr 12 2021, 07:51 AM
Senior Member Group: Members Posts: 973 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region |
Keith Black 96mm pistons from European Motorworks are great Pistons and cylinder combos! or bore you OEM ones if you can.
1) Check you deck hight for your compression Ratio 2) Check your Rocker Geometry too if you change the cylinders or have not done so |
Lo-Fi Version | Time is now: 2nd June 2024 - 03:19 AM |
