Spark Plug Wires, Recommendations |
tvdinnerbythepool |
Apr 13 2021, 07:22 PM
Member Group: Members Posts: 310 Joined: 24-July 18 From: Olympia, WA Member No.: 22,336 Region Association: Pacific Northwest |
Hope you guys and gals are all doing well!
Time to replace plug wires on my 1.7 D-Jet and was wondering on opinions of the group. Some sets seem suspiciously cheap like $25 (IMG:style_emoticons/default/huh.gif) I came across these NGK wires that seemed priced more in line with good quality... https://www.amazon.com/NGK-RC-VWC020-Spark-...2917&sr=8-1 input appreciated! I did search through the forum but a lot of the threads were 10+ years old with some manufacturers NLA. (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) Sunny spring week up here in the PNW |
wndsrfr |
Apr 13 2021, 07:30 PM
Senior Member Group: Members Posts: 1,430 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
Clewett.
steuspeed |
Apr 13 2021, 07:32 PM
Senior Member Group: Members Posts: 1,008 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
Just bought a Clewett Engineering set. They are pretty darn nice. They have an extra nylon sheath over the silicone. Large numbered wires. Not sure if they are any better than a NGK set?
Sycolyst |
Apr 13 2021, 07:36 PM
Newbie Group: Members Posts: 42 Joined: 20-July 19 From: Northern Ohio Member No.: 23,312 Region Association: Upper MidWest |
You can find that same exact set on Rock Auto for $20 cheaper. Decent quality for those dead presidents.
Mikey914 |
Apr 13 2021, 07:37 PM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
For Fuel injected I use the Bremi STI
Got them in stock https://914rubber.com/spark-plug-wire-set-1 However if you have carbs the longer wire plugs will interfere with the intake manifolds. You need the Beru for that application. Yes we do have also . Attached thumbnail(s) |
tvdinnerbythepool |
Apr 13 2021, 09:35 PM
Thanks all!
steuspeed |
Apr 13 2021, 11:54 PM
Have you thought about or know of a source that have pop-in plastic plug wire clips that are larger than stock for larger 7-8mm wires? I noticed the clips on the tins, but they are unusable.
Mark Henry |
Apr 14 2021, 04:04 AM
Just bought a Clewett Engineering set. They are pretty darn nice. They have an extra nylon sheath over the silicone. Large numbered wires. Not sure if they are any better than a NGK set? I just passed on an old set of clewett, the set may have been abused but I couldn't get over the cheap, dirt magnet, torn, nappy, all falling apart sheath. |
Lo-Fi Version | Time is now: 8th June 2024 - 03:15 AM |
