VDO Elec. oil pres. gauge & sender, revisited ... again, UGH! |
914werke |
Apr 15 2021, 04:48 PM
"I got blisters on me fingers" Group: Members Posts: 10,124 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Feeling pretty stupid today (IMG:style_emoticons/default/sad.gif)
I dont recall ever having this problem before just bought parts assembled & worked. But Im doing another, encountered the "key on" gauge pegs situation that Ive now checked with 3 gauges, 2 senders, direct wiring, check & re-check continuity & grounds (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/wacko.gif) (IMG:style_emoticons/default/confused24.gif) Is this failure mode supposed to be TOO MUCH resistance or the LACK OF resistance (open)? |
914werke |
Apr 15 2021, 09:15 PM
its too MUCH resitance ... (IMG:style_emoticons/default/smile.gif)
(in my best "chaurch lady" voice) ...nevermind! (IMG:style_emoticons/default/biggrin.gif) |
DRPHIL914 |
Apr 16 2021, 06:48 AM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Feeling pretty stupid today (IMG:style_emoticons/default/sad.gif) I dont recall ever having this problem before just bought parts assembled & worked. But Im doing another, encountered the "key on" gauge pegs situation that Ive now checked with 3 gauges, 2 senders, direct wiring, check & re-check continuity & grounds (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/wacko.gif) (IMG:style_emoticons/default/confused24.gif) Is this failure mode supposed to be TOO MUCH resistance or the LACK OF resistance (open)? its too MUCH resitance ... (IMG:style_emoticons/default/smile.gif) (in my best "chaurch lady" voice) ...nevermind! (IMG:style_emoticons/default/biggrin.gif) @914werke well mine was doing this when i had a short in the signal on right front and the fuse blew so the gauge was pegged when key was turned on, is this what you are talking about being "too much" , it was a short in my situation , i have to replace the right front signal socket , i thought it was either the fog light switch, flasher or signal relay , and that was why i had asked you about the fog light switch. . if so where was your short? |
framos914 |
Apr 16 2021, 09:25 PM
Member Group: Members Posts: 125 Joined: 15-May 14 From: Corona California Member No.: 17,353 Region Association: Southern California |
I deleted some bad info I posted. I just read that if it pegs with key on and engine off the wire to sender is open. I wonder if you put a ground directly to the gauge and it doesn't peg that verifies an open wire since you had already replaced the sender. |
Robarabian |
Apr 16 2021, 11:14 PM
914 A Roo Group: Members Posts: 592 Joined: 11-February 19 From: Simi Valley, Kalifornia Member No.: 22,865 Region Association: Southern California |
So what was the fix.. I am experiencing something similar right now as well with oil pressure and fuel gauge..
Lo-Fi Version | Time is now: 7th June 2024 - 02:04 AM |
