F.S koni rear shocks |
72914wrx |
Apr 18 2021, 10:51 PM
Member Group: Members Posts: 86 Joined: 5-January 15 From: Fresno Member No.: 18,298 Region Association: None |
Selling one set of rear koni shocks with springs . Asking 150
Attached image(s) |
bdstone914 |
Apr 19 2021, 08:31 AM
bdstone914 Group: Members Posts: 4,533 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Have you removed the springs and tested the shocks by running the adjusters full range and see that they have smooth operation the full range of motion?
The amount of oil build up in the upper shocks shows some leakage has occured. |
72914wrx |
Apr 19 2021, 11:14 AM
No I haven’t willing to take offers . Not sure what is fair on theses . Just a starting point
BillJ |
Apr 19 2021, 11:21 AM
Senior Member Group: Members Posts: 1,106 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None |
I think what Bruce is suggesting is that we need to know if they work or not. If they are shot then they are worth nothing really but we need more info to assess that. Also - are you including the bottom mounting bolts and the lower mount ring? Unless you are going new will need those. Good luck with sale!
ClayPerrine |
Apr 19 2021, 11:50 AM
Life's been good to me so far..... Group: Admin Posts: 15,503 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
If they are shot then they are worth nothing That is not entirely true. If they are shot, you can send them to Koni for rebulid. Yes, it lowers the value of them if they are completely shot, but they are definitely worth more than a dead KYB (AKA scrap metal). Clay |
BillJ |
Apr 19 2021, 12:22 PM
Yes have heard of folks doing that and curious on cost. I had one front shock that wasnt right so just did koni adjustables all around and was under $800 for all new. If rebuilds are reasonable then could be a good path. Good luck seller and Clay appreciate the refinement on my response.
brant |
Apr 19 2021, 12:59 PM
914 Wizard Group: Members Posts: 11,632 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I believe a koni rebuild cost more than a brand new koni
so unless a person really wanted to keep the old shock.. they are essentially worthless if they test bad from taking them apart and checking range of motion |
Tdskip |
Apr 19 2021, 01:03 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
I believe a koni rebuild cost more than a brand new koni so unless a person really wanted to keep the old shock.. they are essentially worthless if they test bad from taking them apart and checking range of motion ^^^^^^ True, like nearly double the cost all-in actually. |
ClayPerrine |
Apr 19 2021, 02:06 PM
I believe a koni rebuild cost more than a brand new koni so unless a person really wanted to keep the old shock.. they are essentially worthless if they test bad from taking them apart and checking range of motion ^^^^^^ True, like nearly double the cost all-in actually. I was not aware it was that expensive to have them rebuilt. Clay |
BillJ |
Apr 19 2021, 02:58 PM
Does that mean you revise your statement Clay? lol. J/K.
In order to test these then assume he needs to remove the springs then make sure the struts are not leaking then what is the behavior he should expect from shocks that are still good? |
bdstone914 |
Apr 19 2021, 08:34 PM
Does that mean you revise your statement Clay? lol. J/K. In order to test these then assume he needs to remove the springs then make sure the struts are not leaking then what is the behavior he should expect from shocks that are still good? Resistance should be firm the full stroke. The adjustemnt should go 2-3/4 turns and stop. Should be much more firm when set on heavy. I tested about 20 and more than half were shot. |
bdstone914 |
72914wrx |
Apr 19 2021, 10:35 PM
Sold pending payment thank you !
Lo-Fi Version | Time is now: 3rd June 2024 - 05:43 AM |
