Green top 2.0 injectors value, lightly used looking to get an idea of value |
DRPHIL914 |
Apr 24 2021, 11:48 AM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
i bought these as brand new in box @ 5-6 years ago, used them for about 2 months while my OEM were sent out for flow test and cleaning. they ended up being perfect so i reinstalled them and put these aside for a rainy day or if one failed. I got them from Otto’s. i am guessing @ $100per? search only found a set of OEM selling for $650.
Attached thumbnail(s) |
steuspeed |
Apr 24 2021, 03:08 PM
Senior Member Group: Members Posts: 1,008 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
I went looking for an OEM replacement last year and the cheapest I found was $224 on ebay. These are not exact match to the OEM as the OEM are darker green and do not have the crimped on elbow hose. OEM has a rubber elbow hose and 2 clamps.
JeffBowlsby |
Apr 24 2021, 04:57 PM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I’m thinking $40 ea./max. They are used, sitting around, no doubt have fuel residue that may be clogging if not corroding them internally and will at least need professional cleaning/pressure testing. We have seen similar sets with very recent documented professional cleaning languish here priced at ~$150. For 4. Probably due to the uncertainty.
steuspeed |
Apr 25 2021, 12:19 AM
I’m thinking $40 ea./max. They are used, sitting around, no doubt have fuel residue that may be clogging if not corroding them internally and will at least need professional cleaning/pressure testing. We have seen similar sets with very recent documented professional cleaning languish here priced at ~$150. For 4. Probably due to the uncertainty. Guess I should have called you Jeff. Nothing but crickets on 914World when I was looking for just one. Shocked you have sets of 4 tested for $150. |
rjames |
Apr 25 2021, 12:37 AM
I'm made of metal Group: Members Posts: 3,955 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
I agree with Jeff. In fact I bought a documented flow tested 2.0 injector from someone here for $50 last year. They seem to pop up somewhat regularly.
Lo-Fi Version | Time is now: 9th June 2024 - 02:06 PM |
