WTB - Fan hub spacer and hardware, and rain tray screws, some various small hardware parts needed |
seanpaulmc |
Apr 25 2021, 09:22 AM
Member Group: Members Posts: 305 Joined: 6-December 16 From: Orlando, FL Member No.: 20,649 Region Association: South East States |
Hardware needs:
1. Rain tray screws, Qty: 2, P/N: N 014 142 3 2. Fan to hub ‘Spacer’, Qty: 1, P/N: 021 119 121 Fan Spacer 3. Would someone also be able to confirm the type of bolts for impeller fan to hub connection? I find the PET hard to interpret in some instances. Item 6 in the diagram shows - N 010 246 4, M8 x 45 hex-head bolt. Is this it? If so, then will need items 6, 7, and 8 (bolt, spring washer, washer). Probably easy to get at a hardware store but checking here first. Thank you, Sean |
914werke |
Apr 25 2021, 12:53 PM
"I got blisters on me fingers" Group: Members Posts: 10,150 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Hardware needs: 1. Rain tray screws, Qty: 2 2. Fan to hub ‘Spacer’ 3. Would someone also be able to confirm the type of bolts for impeller fan to hub connection? Spacer HERE (Ill just send you the M6 pan heads for the rain tray) The (3) impeller bolts are M8-45 Keep in mind there are two styles of impeller, early has a conical snout that has a plastic cap, & late that has that "point" flattened off. The reason thats importent is the early used cap head bolts vs the late using regular hex head. |
seanpaulmc |
Apr 25 2021, 01:05 PM
Hardware needs: 1. Rain tray screws, Qty: 2 2. Fan to hub ‘Spacer’ 3. Would someone also be able to confirm the type of bolts for impeller fan to hub connection? Spacer HERE (Ill just send you the M6 pan heads for the rain tray) The (3) impeller bolts are M8-45 Keep in mind there are two styles of impeller, early has a conical snout that has a plastic cap, & late that has that "point" flattened off. The reason thats importent is the early used cap head bolts vs the late using regular hex head. Hey Rich - Thanks for posting/responding. I'm going to PM you. I'd like to place a bigger order for several items. Thanks, Sean |
Lo-Fi Version | Time is now: 14th June 2024 - 03:27 AM |
