AAARRRGGG Bushing, trailing arm bushing that is |
freezing14 |
Jul 21 2005, 07:58 AM
freezing14 Group: Members Posts: 435 Joined: 21-June 04 From: brockville , Ontario, Canada Member No.: 2,233 |
Got the traling arm off and i am changing the bushing,, the old one were hard to convice out , but the new one doe not want to cooperate, it goes ok on the one side until it hits the second side and then the other one always pops out,,, so what is the best way to put those back in
URY914 |
Jul 21 2005, 08:11 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,863 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
(IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) One of the WORST jobs on a 914.
(IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) |
freezing14 |
Jul 21 2005, 08:26 AM
i know , i have tried the hammer , but is there a trick or should i consider getting a press ( i got a line on a 12 tons)
URY914 |
Jul 21 2005, 08:53 AM
Are you instaling new stock rubber ones or plastic?
Joe Ricard |
Jul 21 2005, 09:23 AM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
New stock Rubber one's ???????
Well my question is did you match fit the Plastic bushing to the shaft and housing? 10lb of bushing won't fit in a 5 lb housing. |
freezing14 |
Jul 21 2005, 09:45 AM
I am using both stock rubber bushing and bolt
Jeffs9146 |
Jul 21 2005, 10:06 AM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
I used a press and a bunch of grease! It went together as smooth as snot! Jeff |
URY914 |
Jul 21 2005, 11:01 AM
Yes, the rubber one are better to press in. Nice and slow and smooth.
Lo-Fi Version | Time is now: 28th May 2024 - 06:23 PM |
