partwerks |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 ![]() |
The horn on a 1975. Can those nuts be removed, so the two terminals can be cleaned underneath?
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,537 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
The horn on a 1975. Can those nuts be removed, so the two terminals can be cleaned underneath? Yes but that is not usually the problem. There is a set of contact points inside that get corrored. You have to drill out the rivets and take the cover off to a cess them. |
partwerks |
The horn on a 1975. Can those nuts be removed, so the two terminals can be cleaned underneath? Yes but that is not usually the problem. There is a set of contact points inside that get corrored. You have to drill out the rivets and take the cover off to a cess them. The earlier set I have, has rivets, but my later one does have any rivets. Almost looks like it is crimped on around the edges, similar to the gauges? As of a year ago, it worked, and so as a last resort, I was going to see if that would help. |
Lo-Fi Version | Time is now: 11th June 2024 - 05:39 AM |
