degreeoff |
I like big butts and I can not lie! ![]() ![]() ![]() Group: Members Posts: 1,622 Joined: 9-February 03 From: Booowieeee MD (near DC) Member No.: 275 Region Association: MidAtlantic Region ![]() |
Hello,
Will the 914-6 intermediate plate fit a side shifter tranny and allow use of the stock throttle setup, I have one lined up for my conversion but don't know if it will work?? If you've BTDT I would love your input. Thanks Fellow teener Josh getting ready to graduate.....INTO A 200HP 6ER!! |
Cap'n Krusty |
Rich Johnson sells a conversion kit that makes it easy, and it works well. Changing the plate runs the risk of damaging the bearings at a cost of over 200 bucks EACH (new prices), needing new gaskets, and the labor to do the swap. The Cap'n
Red-Beard |
"Ya canna change the laws of Physics" ![]() ![]() ![]() Group: Benefactors Posts: 1,124 Joined: 11-February 03 From: Houston, TX Member No.: 288 Region Association: None ![]() ![]() |
I sideshift converted my 914/6 tranny.
You definitely can use the 914/6 plate, but you do have to then do the work to set the pinion depth. |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,423 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
Get a tailshift tranny with the proper intermediate plate. Pull it apart just enough to install the side shifter parts. During reassembly, put the side shifter tail housing on it.
TADA!!! Instant side shifter tranny with the proper /6 throttle linkage. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Red-Beard |
Yep! The early tail shifters have the hole in the plate, just transfer the throttle rod.
Lo-Fi Version | Time is now: 7th July 2025 - 01:28 AM |
