| BillJ |
May 12 2021, 07:12 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,355 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None
I recently picked up a oil pressure gauge for my center console and need to get the sender side. Does anyone make a nice kit that works with our type 4s? Have seen a custom setup with using the oil pressure sensor port and creating a "t" to use both and can probably piece that together myself but a plug and play solution would be nice too. I have a VDO gauge that runs from 0-60psi and 0-5 kgf/cm2 and labeled on face with "I" at the 12 o'clock position and "522" at the 2 o'clock position. back has 3 spades.
I would like to preserve the light as well in the dash so having a solution for both is important to me. Any help appreciated! |
| bbrock |
May 12 2021, 07:42 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains
They used to sell dual pole senders that let you connect both a gauge and the dash light. I bought mine over 30 years ago so don't know if they are still available.
| brant |
May 12 2021, 07:45 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,167 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
Buy a dual pole sensor
You should not really get a T Most stand pipes and T’s used will end up cracking leaking at the worst time |
| BillJ |
May 12 2021, 07:54 AM
Oh great! So would toss the old single pole sensor for the idiot light in the dash and can use existing green/black wire for idiot light then a second line for the center console gauge? Does anyone know the correct sender? Pretty bad at electrical stuff myself but really want to do this one at home.
| FlacaProductions |
May 12 2021, 07:57 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,176 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California
Here's the dual pole - and while they sell it, they don't recommend it (which I find refreshing):
https://vwparts.aircooled.net/VDO-80psi-Oil...m-p/v360006.htm "We don't feel that the VDO 80psi Oil Pressure, 10 X 1mm, Dual Pole Sending Unit is the "right" sender to use for aircooled VW Engines because the oil light comes on at too high a pressure. Stock is 2psi, this comes on at 7-8psi. Aircooled VW Engines usually have a hot idle anywhere from 1.5-7psi when properly built (Proper sized pump), and using the correct viscosity oil (10psi/1k RPM hot cruise). More pressure than this at cruise causes the stock oil cooler to be bypassed, and oil temps skyrocket. When you size the pump and oil viscosity properly, you should see hot idle between 1.5-7psi. If you use a VDO 2-Pole Sending Unit, the idiot light is triggered at 8psi, and you will be constantly freaking out at hot idle wondering "what's wrong". The solution is to use a VDO 1-Pole Sender with the STOCK Oil Light Switch, to get the use of your Oil Pressure Gauge, with the correct operation of the stock oil pressure switch activating your Warning Light. Regardless, we are offering this for you enthusiasts that want a high warning light pressure instead of the 2psi stocker." Also check here: https://www.pegasusautoracing.com/document....DocID=TECH00129 Lots of threads here if you search. 42 Draft Designs used to make a relocation kit with a block that allowed the use of the stock idiot light sender and a 2nd sender for the gauge - but they don't anymore. If you post a WTB, someone might still have one - that's how I got mine.... |
| BillJ |
May 12 2021, 08:14 AM
Definitely interesting. They also sell a splitter block to use the stock sender for the idiot light at 2psi and a single pole for the pressure gauge. Probably best bet is to simply call those guys up and talk through the need.
| mate914 |
May 12 2021, 09:15 AM
Matt ![]() ![]() ![]() Group: Members Posts: 934 Joined: 27-February 09 From: Eagles mere, PA Member No.: 10,102 Region Association: North East States
I think some on here use a paintball gun hose. I ordered one, not here yet.
Matt |
| barefoot |
May 12 2021, 09:21 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,488 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States
There are threads here that discuss adapting a short flex hose and a Tee fitting to use dual senders. need to fab a little bracket to mount the Tee. A 1/8-27 pipe thread is almost exactly the same as the tapered metric thread in the case, so lots use an American thread hose.
| 914werke |
May 12 2021, 10:03 AM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,606 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
& a way to ground the senders ~
| johnhora |
May 12 2021, 10:24 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 902 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None
| BillJ |
May 12 2021, 11:34 AM
I think I am going to get the predrilled block and new one pole sender and a new idiot light sender. Really cheap for all the parts considering and the only thing I am worried about is the line and the install into the block. Seem to remember the builder saying something about the hole being a different size from stock.
Would get these three things straight away then figure out the hose and clamp: http://vwparts.aircooled.net/Oil-Pressure-...21-919-081b.htm http://vwparts.aircooled.net/VDO-Sending-U...0-p/v240850.htm http://vwparts.aircooled.net/VDO-80psi-Oil...F-p/v360003.htm |
| aharder |
May 12 2021, 06:16 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,954 Joined: 6-September 11 From: Dallas Texas Member No.: 13,524 Region Association: Southwest Region
I think some on here use a paintball gun hose. I ordered one, not here yet. Matt I set up a Paint Ball hose and put a 3 Way at the end of it. It has the original Dash Light fitting and a pressure gauge in the engine bay and a Line for my VDO Pressure gauge in the console. I would include some Pic's but I'm on the road. |
| FlacaProductions |
May 12 2021, 07:02 PM
I may be doing this install next week and the engine will be in - which means tight access.
Think it's possible to use a line socket to install the Level 42 Designs remote hose? Just trying to figure out how to get a wrench through the tins and i'm not sure a crows foot will do it. something like this: |
| euro911 |
May 12 2021, 11:40 PM
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,937 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California
Those look like they'd work for great the CHT sensor installation/removal/replacement (XX-mm) ... not sure if you'd need one for the oil pressure sensor (IMG:style_emoticons/default/confused24.gif)
| BillJ |
May 13 2021, 05:16 AM
I may be doing this install next week and the engine will be in - which means tight access. Think it's possible to use a line socket to install the Level 42 Designs remote hose? Just trying to figure out how to get a wrench through the tins and i'm not sure a crows foot will do it. something like this: Those ARE nice! Where can you get them? And 42 Design? |
| FlacaProductions |
May 13 2021, 07:47 AM
Those look like they'd work for great the CHT sensor installation/removal/replacement (XX-mm) ... not sure if you'd need one for the oil pressure sensor (IMG:style_emoticons/default/confused24.gif) wouldn't need them for the stock oil pressure sensor, no - I'd need it for the installation of the hose in that same hole (obviously) for a remote oil pressure sender. it's gotta be tight with the engine in and the tins on. my real issue is that i'm in a different state than my 914 and i only get short bursts of time to mess around with it so i have to try to visualize and plan do research while I'm away. search "line socket" and the appropriate size and you'll find options. that pic came from amazon but there are numerous sources. post a WTB ad here for a 42 Draft Design kit - maybe someone still has one on a shelf. this is what they look like: https://store.ngpracing.com/42-draft-design...cation-kit.html |
| Highland |
May 13 2021, 02:26 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 559 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
Hi @BillJ , thought I'd post a picture of what I did. Before you hook up the idiot light sender, you might want to put a mechanical gauge on that port to compare to your VDO electric gauge. Just as an example, I was getting 4~6 psi at hot (215F) 1000 rpm idle on the VDO while I was getting 12 psi on my mechanical gauge. The VDO seems to read low throughout the range. Not a big deal, just nice to know you have oil pressure even though the gauge may not indicate so (at low rpm and hot days). If you're curious that's a 928 brake line.
| BillJ |
May 13 2021, 02:47 PM
Thanks a ton for the picture that definitely helps! Suppose i could get a mechanical gauge with the rest of the purchase to confirm first. That's a good suggestion. Does the 928 fuel line also serve as a ground?
| HansJan |
May 13 2021, 08:31 PM
Member ![]() ![]() Group: Members Posts: 403 Joined: 5-April 16 From: Sugar Land TX Member No.: 19,860 Region Association: Southwest Region
Hi @BillJ , thought I'd post a picture of what I did. Before you hook up the idiot light sender, you might want to put a mechanical gauge on that port to compare to your VDO electric gauge. Just as an example, I was getting 4~6 psi at hot (215F) 1000 rpm idle on the VDO while I was getting 12 psi on my mechanical gauge. The VDO seems to read low throughout the range. Not a big deal, just nice to know you have oil pressure even though the gauge may not indicate so (at low rpm and hot days). If you're curious that's a 928 brake line. (IMG:style_emoticons/default/agree.gif) The 928 brake line works great. I used it after the standpipe broke and sprayed oil all over the engine. |
| aharder |
May 13 2021, 09:23 PM
Pictures of my set up for both plus 1 in the engine bay
Lo-Fi Version | Time is now: 2nd April 2026 - 06:59 AM |
