trailing arm bushing replacement, need bushing source and advice |
914 RZ-1 |
May 12 2021, 12:21 PM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
I need to replace the trailing arm bushings. These are pressed in to the trailing arm, correct? The bushings are not listed as an item on the PET, it just notes that the trailing arm comes with the bushings. 914rubber doesn't seem to have them. Pelican does (https://www.pelicanparts.com/More_Info/993015335.htm?pn=99-3015-335-M523&SVSVSI=5874&DID=12870), but they are the ones I'm told squeak over time. Is there another source for these? I need a part number as well, unless the Pelican part number (Part #: 99-3015-335-M523) is correct.
What is involved in replacing these? I'm assuming I need to remove the rear trailing arms, which involves removing the brake lines, the e-brake, wheels, etc. Anything else I should look out for? I have a friend who has a press for getting the bearings in and out. Any special tools needed? Thanks! |
mgarrison |
May 12 2021, 12:32 PM
Member Group: Members Posts: 356 Joined: 14-February 20 From: Chandler, AZ Member No.: 23,922 Region Association: Southwest Region |
I got mine from 914Rubber. I replaced shafts as well, but I have not installed either yet...
https://914rubber.com/rear-trailing-arm-bus...for-porsche-914 Mike |
bbrock |
May 12 2021, 04:34 PM
If you want to replicate the OEM bushings, bite the bullet and get Elephant Racing's rubber bushings. I tried 914Rubber's rubber bushings but they did not fit right. Just to be clear, 914R has sold at least two versions of bushing, but last time I looked, it was a little tricky to tell which was which from their web site.. Their polyurethane bushings fit well but are not rubber like OEM, and their rubber bushings came undersized for my car. In contrast, their front A-arm bushings fit great and seem a good replacement for OEM.
Installing the Elephant Racing bushings wasn't too terribly difficult using a pipe clamp and plenty of soap for lube. You can read about my installation here: http://www.914world.com/bbs2/index.php?s=&...t&p=2889310 |
MM1 |
May 12 2021, 06:24 PM
914 obsession continues Group: Members Posts: 608 Joined: 9-May 18 From: Thousand Oaks, CA Member No.: 22,105 Region Association: Southern California |
I researched this quite a bit too, Padawan . . .go with Elephant racing . . .not always easy to get a quote for just the bushings (if you know someone with the installation kit - which you'll want to use) . . .I finally got a quote of $200-ish for just the bushings around a year ago . . .took a little bit of persuasion though as I recall.
bbrock |
May 12 2021, 07:43 PM
I researched this quite a bit too, Padawan . . .go with Elephant racing . . .not always easy to get a quote for just the bushings (if you know someone with the installation kit - which you'll want to use) . . .I finally got a quote of $200-ish for just the bushings around a year ago . . .took a little bit of persuasion though as I recall. Yep. I just emailed them and they got back to me right away. $200 for the bushings alone and if you need the install tools, another $80. But check out the end of this other active thread where @bdstone914 reports on the bushings from Restoration Design. Also note that two people have reported good luck with the 914Rubber version so go figure. http://www.914world.com/bbs2/index.php?showtopic=353373 |
Freezin 914 |
May 12 2021, 07:47 PM
Senior Member Group: Members Posts: 873 Joined: 27-July 14 From: Wisconsin Member No.: 17,687 Region Association: Upper MidWest |
76-914 |
May 14 2021, 09:15 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I need to replace the trailing arm bushings. These are pressed in to the trailing arm, correct? The bushings are not listed as an item on the PET, it just notes that the trailing arm comes with the bushings. 914rubber doesn't seem to have them. Pelican does (https://www.pelicanparts.com/More_Info/993015335.htm?pn=99-3015-335-M523&SVSVSI=5874&DID=12870), but they are the ones I'm told squeak over time. Is there another source for these? I need a part number as well, unless the Pelican part number (Part #: 99-3015-335-M523) is correct. What is involved in replacing these? I'm assuming I need to remove the rear trailing arms, which involves removing the brake lines, the e-brake, wheels, etc. Anything else I should look out for? I have a friend who has a press for getting the bearings in and out. Any special tools needed? Thanks! You can turn the tools on your lathe and save $80. (IMG:style_emoticons/default/beerchug.gif) |
brant |
May 14 2021, 09:27 AM
914 Wizard Group: Members Posts: 11,639 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
don't forget you need a 4 wheel alignment when you are finished...
Mitox |
May 14 2021, 11:32 AM
Member Group: Members Posts: 399 Joined: 26-October 15 From: SW Virginia Member No.: 19,302 Region Association: South East States |
Have you or any others reading this post looked at or tried the Elephant Poly-Bronze trailing arm set-up?
Some of the reviews look good, but ... |
76-914 |
May 14 2021, 11:53 AM
They look to be excellent but overkill for my street needs. Same goes for their control arm bushings. I would expect the ride wouldn't be as smooth on rough surfaces though. I'm also unaware if they have grease fittings or require lubricating occasionally. (IMG:style_emoticons/default/confused24.gif)
Lo-Fi Version | Time is now: 9th June 2024 - 04:15 PM |
