Seat Adjusting Handle |
stickyfingers |
May 12 2021, 03:09 PM
Member Group: Members Posts: 168 Joined: 19-February 21 From: Toronto Member No.: 25,223 Region Association: Canada |
Good day folks. Got a dandy. My 914 came with a busted driver side seat adjusting handle. So I ordered the handles from 914Rubber however I am not sure how I can get the piece of the old handle that's stuck in the channel. Looks like they were special bolts or something. Anyone have any ideas? Is there a quick how to remove the seat to be able to get to the channel (so I can have more room to work with)? See image below of my busted handle (part of the handle piece that you screw into place is still lodged in the channel).
Thank you in advance. |
porschetub |
May 12 2021, 03:23 PM
Advanced Member Group: Members Posts: 4,706 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Good day folks. Got a dandy. My 914 came with a busted driver side seat adjusting handle. So I ordered the handles from 914Rubber however I am not sure how I can get the piece of the old handle that's stuck in the channel. Looks like they were special bolts or something. Anyone have any ideas? Is there a quick how to remove the seat to be able to get to the channel (so I can have more room to work with)? See image below of my busted handle (part of the handle piece that you screw into place is still lodged in the channel). Thank you in advance. Pretty sure they are rivets so you need to drill them out and bolt the new handles on,and yes you need to remove the sets,cheers. |
ndfrigi |
May 12 2021, 03:28 PM
Advanced Member Group: Members Posts: 2,933 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
drill
stickyfingers |
May 13 2021, 09:39 AM
Thank you - I located a post to see how to do this.
Mikey914 |
May 14 2021, 07:20 PM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
You got it,
We designed them to simply screw on wher ethe old ones came off. And if you brake mine we will replace it for free LIFETIME WARRANTY |
Lo-Fi Version | Time is now: 9th June 2024 - 05:20 PM |
