FS 1.8L Core Heads |
tyfighter123 |
May 12 2021, 04:06 PM
Newbie Group: Members Posts: 41 Joined: 22-September 16 From: Grand Junction Member No.: 20,422 Region Association: Rocky Mountains |
davep |
May 12 2021, 08:36 PM
914 Historian Group: Benefactors Posts: 5,152 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
This is hardly enough information to get any interest.
bdstone914 |
May 13 2021, 07:47 AM
bdstone914 Group: Members Posts: 4,537 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Look like 1.7 heads from the gap between the valves.
Al Meredith |
May 13 2021, 01:51 PM
Senior Member Group: Members Posts: 960 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
look like 2L .look at the spark plug location. also the adjuster screws look like the larger 10MM and not the 8MM as on the 1.7
Puebloswatcop |
May 14 2021, 05:48 AM
Senior Member Group: Members Posts: 1,389 Joined: 27-December 14 From: Mineola, Texas Member No.: 18,258 Region Association: Southwest Region |
Can you please clarify what size heads these are and maybe post a couple more pics. Are there any other issues with the heads, such as broken pieces, studs, etc? Might be interested. Thanks
tyfighter123 |
May 19 2021, 11:14 AM
scottthephotog |
May 19 2021, 03:00 PM
Member Group: Members Posts: 187 Joined: 20-November 18 From: Euless, TX Member No.: 22,667 Region Association: Southwest Region |
Those are definitely not 2.0 heads. 2.0 heads have three intake studs, and these have four. These are either 1.7 or 1.8 heads.
davep |
May 19 2021, 04:30 PM
I agree, so now to determine which variety. Do a little cleaning and see what the casting part # actually is. Example location here:
914LIVE |
May 20 2021, 08:24 AM
Newbie Group: Members Posts: 10 Joined: 29-June 10 From: Portland, Oregon. Member No.: 11,890 Region Association: None |
Simple answer : VW Bus 2.0 Liter heads !!! ================================= |
tyfighter123 |
May 28 2021, 10:25 AM
tyfighter123 |
Jun 10 2021, 10:27 AM
Jonathan Livesay |
Jun 10 2021, 10:50 AM
Senior Member Group: Members Posts: 742 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None |
tyfighter123 |
Jun 10 2021, 10:56 AM
It's not there.
What is that last digit? It should be either J Q H S or not there at all. 021 101 371 1.7 021 101 371 J 1.7 021 101 371 Q 1.7 021 101 371 H 1.8 Bus 021 101 371 S 1.8 Bus Also I think 2 liter bus heads have square exhaust ports? |
Shivers |
Jun 10 2021, 12:19 PM
Senior Member Group: Members Posts: 2,427 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
That is a russian S...Upside down and backwards. (IMG:style_emoticons/default/smile.gif) It's not shaped like the 2, casting error?
DC_neun_vierzehn |
Jun 11 2021, 07:04 AM
Member Group: Members Posts: 395 Joined: 16-November 20 From: Delaware Shore Member No.: 24,893 Region Association: MidAtlantic Region |
I agree, so now to determine which variety. Do a little cleaning and see what the casting part # actually is. Example location here: Curious … what is the best way to clean up 914 heads safely? @davep |
davep |
Jun 11 2021, 11:37 AM
That can be tricky. Sandblasting or glass bead can embed itself into surfaces. Internal surfaces might allow the grit to get into the oil or other undesirable places. Soda blasting would be preferred. However wire brushing or polishing of the surfaces after blasting should remove most embedded grit.
mepstein |
Jun 11 2021, 12:10 PM
914-6 GT in waiting Group: Members Posts: 19,314 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I agree, so now to determine which variety. Do a little cleaning and see what the casting part # actually is. Example location here: Curious … what is the best way to clean up 914 heads safely? @davep Ultrasonic cleaner |
euro911 |
Jun 12 2021, 02:14 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
That can be tricky. Sandblasting or glass bead can embed itself into surfaces. Internal surfaces might allow the grit to get into the oil or other undesirable places. Soda blasting would be preferred. However wire brushing or polishing of the surfaces after blasting should remove most embedded grit. (IMG:style_emoticons/default/agree.gif) ... That's why I put a separate dedicated soda-blasting cabinet together (IMG:style_emoticons/default/idea.gif) |
tyfighter123 |
Aug 2 2021, 08:57 PM
Bump make me an offer
Lo-Fi Version | Time is now: 9th June 2024 - 10:03 AM |
