Carb Identification |
cause |
May 20 2021, 12:48 PM
Newbie Group: Members Posts: 39 Joined: 6-May 21 From: new york Member No.: 25,514 Region Association: None |
cause |
May 20 2021, 12:49 PM
Superhawk996 |
May 20 2021, 01:32 PM
914 Guru Group: Members Posts: 5,892 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Sarcasm Alert:
Rebuild kit: https://www.pelicanparts.com/More_Info/WEBK...BiABEgKvYfD_BwE On a more serious note -- I think that two barrel progressive carb was called a DFEV by Weber. Others with more knowlege of those progressives will chime in. DFEV kits: https://www.jbugs.com/product/43-5804.html?...AyABEgIT7fD_BwE |
Al Meredith |
May 20 2021, 03:18 PM
Senior Member Group: Members Posts: 960 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
Weber 32-36 kits are available from most suppliers , VW and 914. on a 914 engine you should increase the size of the Idle jet.
Shivers |
May 20 2021, 04:19 PM
Senior Member Group: Members Posts: 2,423 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Friends don't let friends rebuild center mounted progressive carburetors. That said: https://www.ebay.com/itm/191571335298?_trkp...IYaAntUEALw_wcB
SirAndy |
May 20 2021, 04:52 PM
Resident German Group: Admin Posts: 41,676 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Superhawk996 |
May 20 2021, 05:09 PM
Just noticed OP is pretty new.
@cause Maybe a harsh response to the new guy. 1st off (IMG:style_emoticons/default/welcome.png) Maybe a brief explanation is in order. Pulling fuel & air mix though long runner tubes like that is not desirable. Fuel tends to come out of suspension as it contacts long tube runners. Especially when engine is cold and/or temps outside are cold. Usually engine power is lost with this setup. It does work (meaning the car runs) and was done to lots of cars back in the day - usually due to cost constraints. Lot's of other info on the Web and on this site if you want more details on why progressive carbs aren't in favor. Hopefully you can appreciate the cynical humor. |
IronHillRestorations |
May 20 2021, 05:33 PM
I. I. R. C. Group: Members Posts: 6,729 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
The single two barrel progressive carb is a popular budget conversion, and with a good carb pretty fail safe, but also lacking in performance. They work, just not great.
The distance from the carb to the combustion chamber is too far and results in a remarkable flat spot (stumble, bog, fall on it's face) at hard acceleration from low rpms. In very cold weather they're terrible because they never get warmed up, not that anyone drives a 914 in that kind of cold anymore. Dual (definitely not duel) Weber IDF's or Delorto duals is the way to go and will help your 914 to perform like a sports car. |
930cabman |
May 20 2021, 05:52 PM
Advanced Member Group: Members Posts: 3,144 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Redline has a twin Weber 40IDF setup for reasonable $$.
Best of luck and welcome aboard |
cause |
May 21 2021, 05:30 AM
Yeah this is all info that I figured. I'm not new to mechanics, just this car.
Following the above I just bought the dual setup |
bbrock |
May 21 2021, 08:08 AM
You made a good choice. To confirm what others have said, I tried running the single carb setup on a 1.7L and a VW bus. Both ran well enough for grocery getters but would bog down on acceleration and it took the soul out of the 914. Both would freeze up half way to work on cold days and leave me stranded at the side of the road trying to thaw the runners and the block of ice around he carb. Back then you could by dual 34ICT kits for not much more than the single carb so that's what I replaced the singles with. Still no top end but I didn't have to sweet talk them into moving every time I stepped on the gas and were much less prone to freezing (although it still happened on rare occasions. (IMG:style_emoticons/default/welcome.png)
Root_Werks |
May 21 2021, 02:41 PM
Village Idiot Group: Members Posts: 8,337 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Yeah this is all info that I figured. I'm not new to mechanics, just this car. Following the above I just bought the dual setup Good call! You'll be much happier with a dual setup. And yes, (IMG:style_emoticons/default/welcome.png) |
Superhawk996 |
May 21 2021, 03:54 PM
Yeah this is all info that I figured. I'm not new to mechanics, just this car. Following the above I just bought the dual setup Man. I think this might be the 1st time someone has take the dual IDF advice so easily. (IMG:style_emoticons/default/laugh.gif) We need more members like @cause . You won't regret it. I originally ran my 1.7L on IDF's and stock cam. At least had decent throttle response though I don't think I picked up any power (didn't understand FI back then). Later on rebuilt to 1911 cc with 96mm pistons, slightly higher CR, and a cam suitable to carbs. Then life got way more fun! |
roblav1 |
May 21 2021, 05:59 PM
Senior Member Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
That's what we in Navy would say - give it the flotation test.
cause |
Jun 18 2021, 03:23 PM
Finally had some time today to install the kit I got off of eBay...holy crap what a difference!!! The old kit that was in there had broken gaskets and everything was loose.
I ordered the correct jets needed to adjust them a little more, but in the meantime the pickup, throttle response and sound are absolutely incredible. It also starts so much easier now too |
Root_Werks |
Jun 18 2021, 03:44 PM
Very cool! Dual carbs are so much better than a single carb having fuel travel through those long tubes.
Plus, yes, they sound cool! |
Shivers |
Jun 18 2021, 05:20 PM
Finally had some time today to install the kit I got off of eBay...holy crap what a difference!!! The old kit that was in there had broken gaskets and everything was loose. I ordered the correct jets needed to adjust them a little more, but in the meantime the pickup, throttle response and sound are absolutely incredible. It also starts so much easier now too Just a suggestion, I see you are on the right coast. They make a 914-6 hand throttle kit. When it's cold you can bring up the idle for warm up and not have to keep a foot on the throttle. |
JamesM |
Jun 18 2021, 11:16 PM
Senior Member Group: Members Posts: 1,915 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Finally had some time today to install the kit I got off of eBay...holy crap what a difference!!! The old kit that was in there had broken gaskets and everything was loose. I ordered the correct jets needed to adjust them a little more, but in the meantime the pickup, throttle response and sound are absolutely incredible. It also starts so much easier now too You think that is impressive... Try fuel injection (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 8th June 2024 - 12:49 AM |
