Six vs four, Trans question |
mepstein |
May 27 2021, 06:14 PM
914-6 GT in waiting Group: Members Posts: 19,305 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Please remind me how to tell the difference between a four and six transmission case. Thanks!
76-914 |
May 27 2021, 06:21 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
$2500 (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/lol-2.gif)
IronHillRestorations |
May 27 2021, 06:28 PM
I. I. R. C. Group: Members Posts: 6,724 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
They have a threaded hole for the throttle pivots shaft, and the shift mechanism at the tail isn’t like the 4cyl
mepstein |
May 27 2021, 06:38 PM
Retroracer |
May 27 2021, 07:15 PM
Senior Member Group: Members Posts: 614 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest |
As I recall the casting is different along the centerline underneath - there should be an extra lump on -6 version, as well as a different part number?
Also, as @76-914 points out, $2500. - Tony |
davep |
May 27 2021, 08:16 PM
914 Historian Group: Benefactors Posts: 5,151 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
mepstein |
May 27 2021, 08:39 PM
Three things that I look for are the serial # which is a 7xxxxxx # for a six, The serial is either stamped along the bottom rib or off to the side on a flat made especially for it, and the bell housing usually has a protrusion on the right side low down (perhaps a cable guide). Perfect. Thanks! |
Cairo94507 |
May 27 2021, 09:06 PM
Michael Group: Members Posts: 9,808 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
davep |
May 28 2021, 10:28 PM
Here is what is should look like on a Six: Not all, but I would like to narrow the range down (a lot) from between 7500215 to 7501454; up to 215 I have photos of the serial along the rib as is usual for a 914 trans. I just need serial photos of many more six trans. The feature on the case is also present on the early version: These were 911 trans cases albeit with the breather vent relocated. |
ClayPerrine |
May 28 2021, 10:44 PM
Life's been good to me so far..... Group: Admin Posts: 15,498 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
That "Feature" on the trans bell housing on the sixes, and the loop on the side cover, are there because Porsche was using the same case on the 70 and 71 911, with the 225mm pull type clutch. That is the anchor for the end of the 911 clutch cable and the loop is the cable guide.
The ones on the fours were a Porsche design from 69, that was built by VW. And they have the markings to prove it. If you look in the bell housing on a 914-6 transmission, the pad that the ball stud is in is oval shaped. The clutch arm pivot on the 70-71 911 was mounted in a slightly different place. You can combine a 70-71 911 trans with the pull type 225mm clutch with 914 side shifter parts and make a transmission that will work on anything up to a 3.2 engine using factory parts. The drawback is you have to use the 70-71 911 pressure plate and release bearing. And the release bearing is well over $300.00 for a new one. But you do get a 914 that doesn't need a pulley on the side of the transmission. So the clutch tube in the chassis has no stress on it and is just a guide tube. Yes, I know this works. I have one that I took out of my car still attached to a 73 2.4 MFI motor sitting on a dolly in my garage. I used a 76 911 clutch cable to hook it up. |
mlindner |
May 29 2021, 07:51 AM
Senior Member Group: Members Posts: 1,525 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
Not to go off topic of Identification but are gears and final drive the same. Thanks, Mark
ClayPerrine |
May 29 2021, 07:54 AM
mepstein |
May 29 2021, 11:23 AM
Found one in my stash. Is this a six case or a converted 911 trans?
Attached image(s) |
gms |
May 29 2021, 12:26 PM
Advanced Member Group: Members Posts: 2,695 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
911
mepstein |
May 29 2021, 01:16 PM
gandalf_025 |
May 29 2021, 01:28 PM
Senior Member Group: Members Posts: 1,456 Joined: 25-June 09 From: North Shore, Massachusetts Member No.: 10,509 Region Association: North East States |
This, from my car.... # 619
914werke |
May 30 2021, 09:33 AM
"I got blisters on me fingers" Group: Members Posts: 10,115 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
isnt the shatf hole on the intermediate plate?
fixer34 |
May 30 2021, 05:00 PM
Senior Member Group: Members Posts: 1,085 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest |
davep |
May 30 2021, 06:58 PM
Thanks very much for those images of the trans #'s. That pulls the start of the reinforced case back much earlier. Interesting about the V-notch. That feature is not used on the 914/6, correct?
fixer34 |
May 30 2021, 07:07 PM
Thanks very much for those images of the trans #'s. That pulls the start of the reinforced case back much earlier. Interesting about the V-notch. That feature is not used on the 914/6, correct? I don't believe there was anything ever attached there and I've had mine over 40yrs. |
Lo-Fi Version | Time is now: 1st June 2024 - 12:14 AM |
