clunk while accelerating 1974 2.0 |
dax1969 |
Jun 2 2021, 08:32 AM
Member Group: Members Posts: 362 Joined: 10-March 14 From: belgium Member No.: 17,103 Region Association: None |
Hi guys,
1974 2.0 When I accelerate from a stop I can feel a clunk in the clutch pedal and (I think) feel it in the shifter. It happens only when I engage the clutch and start accelerating. no clunk when shifting to second or third or 4th or 5th, just a clunk when I lift the clutch pedal a few centimeters and accelerate. Also nothing is felt while downshifting. No grinding of gears, shifting is smooth .. Any ideas ? Adjustment needed of the clutch cable ? What and how would you check/test ? Clutch, pressure plate, throwout bearing are all new. thks Dax |
MDTerp |
Jun 2 2021, 08:37 AM
Member Group: Members Posts: 102 Joined: 20-May 08 From: Maryland Member No.: 9,075 Region Association: MidAtlantic Region |
When I had this problem it was the engine mounts.
rgalla9146 |
Jun 2 2021, 08:44 AM
Advanced Member Group: Members Posts: 4,569 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
When I had this problem it was the engine mounts. (IMG:style_emoticons/default/agree.gif) The front engine mounts are seperated and allow the engine to lift and thump back down |
Dr Evil |
Jun 2 2021, 09:09 AM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
When I had this problem it was the engine mounts. (IMG:style_emoticons/default/agree.gif) The front engine mounts are seperated and allow the engine to lift and thump back down Yup, you can lightly jack under the engine and see if it lifts from the bar, that would show side and failure point. Been there (IMG:style_emoticons/default/wink.gif) |
914_teener |
Jun 2 2021, 11:04 AM
914 Guru Group: Members Posts: 5,205 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
When I had this problem it was the engine mounts. (IMG:style_emoticons/default/agree.gif) The front engine mounts are seperated and allow the engine to lift and thump back down +3 (IMG:style_emoticons/default/agree.gif) |
ndfrigi |
Jun 2 2021, 11:08 AM
Advanced Member Group: Members Posts: 2,933 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
maybe this will give you idea how the engine mount look
http://www.914world.com/bbs2/index.php?sho...334845&st=0 or maybe your clutch tube is/was hitting the shifter when pushing your clutch pedal. check the weld of the front clutch tube to the left side of the tunnel(left side of shifter from the tunnel). |
dax1969 |
Jun 3 2021, 09:54 AM
Ok will investigate the engine mounts... transmission mounts are new, swaybar
same. Thks, will report back |
Lo-Fi Version | Time is now: 6th June 2024 - 03:19 PM |
