Relay Board repair 914, which compound to seal |
Medtner3 |
Jun 2 2021, 07:39 PM
Member Group: Members Posts: 180 Joined: 7-July 20 From: Cedar Park Member No.: 24,467 Region Association: None |
I have an exposed area of the relay board where a previous soldering was done. Should I use liquid electrical tape or potting compound to seal it? The existing potting compound does have some cracks and is dry and brittle. I think a quick fix of some liquid electrical tape would work but I want to make sure I can get whatever I use off in the event that I have future problems with the board and wish to restore it. Right now the board works but if I don't seal the copper traces I am sure that won't last.
Dave_Darling |
Jun 2 2021, 10:36 PM
Use any electrical potting compound you like. I think just about any modern one will hold up to the conditions in the engine bay.
--DD |
914Sixer |
Jun 3 2021, 06:20 AM
914 Guru Group: Members Posts: 8,903 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
You need to clean ALL the tar off. You will be surprised what you will find.
bdstone914 |
Jun 3 2021, 07:04 AM
bdstone914 Group: Members Posts: 4,536 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
You need to clean ALL the tar off. You will be surprised what you will find. @Medtner3 Easy way to clean off the tar is put the board in boiling water. If you do it on a stove place the board in with tar sode up. Let it soak for a while use gloves and a chisel to scrap off the tar. Be carefull to not catch any of the traces. It is a 5 minute job. An old crock pot works well. |
930cabman |
Jun 3 2021, 06:42 PM
Advanced Member Group: Members Posts: 3,144 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
You need to clean ALL the tar off. You will be surprised what you will find. @Medtner3 Easy way to clean off the tar is put the board in boiling water. If you do it on a stove place the board in with tar sode up. Let it soak for a while use gloves and a chisel to scrap off the tar. Be carefull to not catch any of the traces. It is a 5 minute job. An old crock pot works well. Thank you for the tip, I will following this method |
Medtner3 |
Jun 3 2021, 06:45 PM
You need to clean ALL the tar off. You will be surprised what you will find. @Medtner3 Easy way to clean off the tar is put the board in boiling water. If you do it on a stove place the board in with tar sode up. Let it soak for a while use gloves and a chisel to scrap off the tar. Be carefull to not catch any of the traces. It is a 5 minute job. An old crock pot works well. Thanks Bruce great tip I guess the consensus is go ahead and strip it all off not just patch a little bit and fix it for the next fifty years I was leaning that direction |
Lo-Fi Version | Time is now: 8th June 2024 - 11:07 PM |
