dhuckabay |
Member ![]() ![]() Group: Members Posts: 224 Joined: 14-June 20 From: Idaho Member No.: 24,379 Region Association: Pacific Northwest ![]() ![]() |
aturboman |
Member ![]() ![]() Group: Members Posts: 135 Joined: 18-October 11 From: CA Member No.: 13,687 Region Association: None ![]() |
Early mirrors are defined by a much more acute 90' angle between the head and base stem as indicated in the red circled area.
Effectively its similar to a mitered corner in wood working, this is the later style with a curved 90' Hope this helps. ![]() |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,908 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Mirror size also determines if it is early or late. Early is smaller.
dhuckabay |
Early mirrors are defined by a much more acute 90' angle between the head and base stem as indicated in the red circled area. Effectively its similar to a mitered corner in wood working, this is the later style with a curved 90' Hope this helps. ![]() Many thanks. I now have to see if one can be found. Any clue when the style changed? |
Cairo94507 |
Michael ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,841 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California ![]() ![]() |
dhuckabay |
Here is the correct side mirror for early cars- like a '71. The problem is these mirrors are getting old. Mine are original to my car and the glass is a bit loose. It is on my list to fix. Probably try to shim the glass tight with something you would never see. ![]() Perfect, thanks for the picture. Clay picked it out a distance, am in awe. Think you are right, going to be tough to find. First peek showed nothing. |
wonkipop |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,407 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille ![]() ![]() |
if you can't find one in usa, i have one here on the other side of the world.
it was given to me gratis 30 years ago by a bloke in wisconsin when people used to give away 914 stuff. i had it set up initially as my rhd mirror for rhd until i got hold of a correct later mirror. you just spin it around an back again etc for lh side. its not absolutely perfect. the glass has spots. its no use to me. you might find yourself a better one in star spangled banner land. you can PM me if you need to. ![]() ![]() ![]() |
gereed75 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,261 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States ![]() ![]() |
Not super hard to find.
http://www.914world.com/bbs2/index.php?showtopic=353400 Not sure exactly when they changed - I seem to recall somewhere around mid 71 |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,534 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
Clay picked it out a distance, am in awe. Don't be. It is just 35 years of fooling with these little cars. The only difference between early and late mirrors is the elbow. The rest of the mirror is identical. The later mirror elbow moves the mirror slightly outboard from the early mirror. And you can get kits to replace the glass. I have two early mirrors, one is on Elwood, and the other will be going on the right side of Elwood. I have never understood the reasoning behind not having a right hand mirror (Or left for those who shift with the left hand). It makes it easier to change lanes and look for the cops. Clay |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,322 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Clay picked it out a distance, am in awe. Don't be. It is just 35 years of fooling with these little cars. The only difference between early and late mirrors is the elbow. The rest of the mirror is identical. The later mirror elbow moves the mirror slightly outboard from the early mirror. And you can get kits to replace the glass. I have two early mirrors, one is on Elwood, and the other will be going on the right side of Elwood. I have never understood the reasoning behind not having a right hand mirror (Or left for those who shift with the left hand). It makes it easier to change lanes and look for the cops. Clay The early mirror is smaller. Glass is different. Stainless steel back is smaller. Gaskets are different. |
Larmo63 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California ![]() |
Mark is right, almost everything on the older mirror is different.
The base seems to be the same. |
wonkipop |
Clay picked it out a distance, am in awe. Don't be. It is just 35 years of fooling with these little cars. The only difference between early and late mirrors is the elbow. The rest of the mirror is identical. The later mirror elbow moves the mirror slightly outboard from the early mirror. And you can get kits to replace the glass. I have two early mirrors, one is on Elwood, and the other will be going on the right side of Elwood. I have never understood the reasoning behind not having a right hand mirror (Or left for those who shift with the left hand). It makes it easier to change lanes and look for the cops. Clay exactly. makes me wonder how i ever drove it with just one mirror 30 years ago when i was doing right hand shifting. i think my 914 was the only car i ever had with just one mirror. even my old vws had two mirrors in aus. we had J cars in the 60s with the mirrors way out near the front end of the mudguards. an experience! kind of like reverse tunnel vision. |
Lo-Fi Version | Time is now: 15th June 2024 - 11:32 AM |
