Sagging Rear End, Suspension Recommendations |
Lfrate02@hotmail.com |
Jun 4 2021, 09:42 AM
Newbie Group: Members Posts: 11 Joined: 17-March 13 From: MA Member No.: 15,664 Region Association: North East States |
Hello! I have a 72 1.7 and the back end is sagging and now bottoming out over bumps. I know it’s time to redo things and am looking for recommendations for parts as well as a shop in Mid-coast Maine. I was thinking springs and shocks. I only drive on the roads and want both comfort and performance. Race/AX spec not necessary. Thx.
mepstein |
Jun 4 2021, 10:14 AM
914-6 GT in waiting Group: Members Posts: 19,315 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
New shocks and springs will fix this. Don't toss the old shocks since you need to move over a couple parts to the new assembly. Your local Garage can easily do this fix or you can do it yourself. No special tools are required.
windforfun |
Jun 4 2021, 10:48 AM
Senior Member Group: Members Posts: 1,838 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
100 lb Weltmeister springs. BTDT.
Jun 4 2021, 11:31 AM
New shocks and springs will fix this. Don't toss the old shocks since you need to move over a couple parts to the new assembly. Your local Garage can easily do this fix or you can do it yourself. No special tools are required. How about this kit? http://www.autoatlanta.com/Porsche-Rear-Co...RSRRCOK914.html |
mepstein |
Jun 4 2021, 11:44 AM
New shocks and springs will fix this. Don't toss the old shocks since you need to move over a couple parts to the new assembly. Your local Garage can easily do this fix or you can do it yourself. No special tools are required. How about this kit? http://www.autoatlanta.com/Porsche-Rear-Co...RSRRCOK914.html Doesn’t include shocks. The springs may be more than you want for a street car. Adjustability is nice but a stock set up will work fine for a street car. It just depends what you want out of your car. If you want a nice riding street car, find Boge shocks, front and rear and 100lb springs. A little more performance oriented and slightly firmer, use Bilstein heavy duty shocks (not sport, they are even stiffer). I’m assuming if you rear shock and springs have failed, your front strut inserts also need replacement. It’s also an easy diy job if you choose. |
Lo-Fi Version | Time is now: 10th June 2024 - 12:47 AM |
