Is one carb on a 73 1.7 ok |
rosenfe |
Jun 4 2021, 10:00 AM
Senior Member Group: Members Posts: 557 Joined: 14-October 13 From: northern california Member No.: 16,512 Region Association: None |
Looking at a 73 1.7 with one carb. Is this a deal breaker?
JeffBowlsby |
Jun 4 2021, 10:07 AM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Not a deal breaker if that’s the only kludged repair the PO did. Look for other band aid repairs. If all is ok then it should at least reduce the price by the cost to replace that carb. If not, don’t buy it.
The cheapest 914 is the most expensive 914 you can buy. |
SirAndy |
Resident German Group: Admin Posts: 41,675 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Looking at a 73 1.7 with one carb. Is this a deal breaker? Not a deal breaker if the rest of the car checks out. The single carb can easily be replaced. There are 3 major issues you need to look out for: - Rust - Corrosion - Fe2O3•32H2O (IMG:style_emoticons/default/bye1.gif) |
Mark Henry |
Jun 4 2021, 12:27 PM
There are 3 major issues you need to look out for: - Rust - Corrosion - Fe2O3•32H2O (IMG:style_emoticons/default/bye1.gif) Nerd! (IMG:style_emoticons/default/lol-2.gif) |
rosenfe |
Jun 4 2021, 01:45 PM
I’ve had 2 914, but both f I.isn’t adding 2 carbs without cam change problematic?
SirAndy |
Jun 4 2021, 01:52 PM
I’ve had 2 914, but both f I.isn’t adding 2 carbs without cam change problematic? It's only problematic if you are expecting to gain performance by adding carbs to an engine with a FI cam. It will run just fine, just not as good as with the original FI in good working order. Plus, now you have to deal with re-jetting every time you dive up/down a mountain. (IMG:style_emoticons/default/shades.gif) |
Tdskip |
Jun 4 2021, 05:46 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Two carbs, not oversized, are significantly better than one.
Lo-Fi Version | Time is now: 7th June 2024 - 03:35 AM |
