914 Steering wheel fitment |
MM1 |
Jun 13 2021, 05:00 PM
914 obsession continues Group: Members Posts: 608 Joined: 9-May 18 From: Thousand Oaks, CA Member No.: 22,105 Region Association: Southern California |
Are all 914 steering wheels interchangeable for all years?
I’m looking at purchasing a 1976 2L steering wheel (here) and am wondering if the spline count, depth, etc. allow it to fit a 1974 (engine size unknown) and a 1973 1.7L? |
bdstone914 |
Jun 13 2021, 05:10 PM
bdstone914 Group: Members Posts: 4,536 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
No not all the same but a 73 or 74 wheel will fit.
The 70-71 wheels are different. The hub and cancel ring are different. The spline is the same for all wheels. @914sixer Not completly correct @mm1 Attached thumbnail(s) |
914Sixer |
Jun 13 2021, 05:12 PM
914 Guru Group: Members Posts: 8,903 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
70-71 turn signal cancel ring is different and will not work with 72-76 unless changed out. All the wheels are the same in all other respects.
Yes, 76 will interchange with the 72-76 models. |
MM1 |
Jun 13 2021, 05:14 PM
Thanks, Bruce.
So the 76 wheel should fit with no changes to both the 73 and the 74, and the 73 wheel should fit the 74 with no changes - correct? |
bdstone914 |
Jun 13 2021, 06:37 PM
mepstein |
Jun 13 2021, 07:06 PM
914-6 GT in waiting Group: Members Posts: 19,313 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
If the wheel ends in “10”, it’s early and fits 70-71. If it ends in “11” it’s mid and late and will fit 72-76
An early wheel has a Porsche hub while later uses a VW design. Also, early has a flat front to the hub while the later ones are dished. |
MM1 |
Jun 14 2021, 01:27 AM
Thank you, Gentlemen!
Lo-Fi Version | Time is now: 7th June 2024 - 07:08 PM |
