MM1
Jun 13 2021, 05:00 PM
Are all 914 steering wheels interchangeable for all years?
I’m looking at purchasing a 1976 2L steering wheel (here) and am wondering if the spline count, depth, etc. allow it to fit a 1974 (engine size unknown) and a 1973 1.7L?
bdstone914
Jun 13 2021, 05:10 PM
No not all the same but a 73 or 74 wheel will fit.
The 70-71 wheels are different. The hub and cancel ring are different. The spline is the same for all wheels.
@914sixer Not completly correct
@mm1
914Sixer
Jun 13 2021, 05:12 PM
70-71 turn signal cancel ring is different and will not work with 72-76 unless changed out. All the wheels are the same in all other respects.
Yes, 76 will interchange with the 72-76 models.
MM1
Jun 13 2021, 05:14 PM
Thanks, Bruce.
So the 76 wheel should fit with no changes to both the 73 and the 74, and the 73 wheel should fit the 74 with no changes - correct?
bdstone914
Jun 13 2021, 06:37 PM
QUOTE(MM1 @ Jun 13 2021, 04:14 PM)
Thanks, Bruce.
Yes
Jun 13 2021, 07:06 PM
If the wheel ends in “10”, it’s early and fits 70-71. If it ends in “11” it’s mid and late and will fit 72-76
An early wheel has a Porsche hub while later uses a VW design.
Also, early has a flat front to the hub while the later ones are dished.
MM1
Jun 14 2021, 01:27 AM
Thank you, Gentlemen!
