Gas coming out my exhaust pipes |
Trippin |
Jun 20 2021, 05:38 PM
Newbie Group: Members Posts: 8 Joined: 11-January 11 From: Spotsylvania, VA Member No.: 12,581 Region Association: MidAtlantic Region |
Need some help. I hadn’t nt started my 914 in about a year and a half. When I went to start it today it didn’t want to fire up. After numerous attempts if would fire up and run for about a second and cut off. After doing that a dozen times. I noticed a pool of gas which appeared to come out of my tail pipes. It’s a 1.8l with dual carbs. Just looking for some suggestions as to what might be cause the gas to come out the tail pipes.
Thanks in advance Tripp |
JOEPROPER |
Jun 20 2021, 05:55 PM
The answer is "no" unless you ask... Group: Members Posts: 1,184 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States |
Will probably need to go thru the carbs. Old gas causes carburetor problems. Float, needle and seat...
930cabman |
Jun 20 2021, 06:00 PM
Advanced Member Group: Members Posts: 3,144 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Needle valve stuck open? Float stuck?
tvdinnerbythepool |
Jun 20 2021, 07:34 PM
Member Group: Members Posts: 310 Joined: 24-July 18 From: Olympia, WA Member No.: 22,336 Region Association: Pacific Northwest |
I 3rd the float. Had the same issue with my Generator. That came out of the exhaust and also filled up the crank case. Pulled the dipstick to check oil level and got a shot a gasoline in my face! Lol!
Good luck with the fix and get driving that thing! (IMG:style_emoticons/default/beerchug.gif) |
euro911 |
Jun 20 2021, 09:06 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
(IMG:style_emoticons/default/agree.gif) ... sounds like you're dumping raw fuel into the cylinders due to the needle valve(s) sticking open and over-filling the float bowl(s).
Lo-Fi Version | Time is now: 7th June 2024 - 09:22 AM |
