Accelerator cable connector, Who sells the part ? |
jim_hoyland |
Jun 23 2021, 01:11 PM
Get that VIN ? Group: Members Posts: 9,318 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Need to find a seller for that piece that connects the accelerator cable to the pedal cluster.
mepstein |
Jun 23 2021, 01:30 PM
914-6 GT in waiting Group: Members Posts: 19,313 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
If you show me a pic of the part and I have it, I will send it to you.
jim_hoyland |
Jun 23 2021, 06:07 PM
If you show me a pic of the part and I have it, I will send with the studs. Thanks, cars not here; IIRC the accelerator cable attaches to the pedal cluster with a ball-cup fitting that thread onto the cable end. Attached image(s) |
SO.O.C914er |
Jun 23 2021, 08:57 PM
Senior Member Group: Members Posts: 1,263 Joined: 18-July 16 From: Mission Viejo Ca Member No.: 20,199 Region Association: Southern California |
Hi Jim, I believe pelican parts has this part.
Montreal914 |
Jun 23 2021, 09:09 PM
Senior Member Group: Members Posts: 1,585 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
Isn't there a pin that goes in there to ensure the socket stays on the ball?
Don914 |
Jun 23 2021, 09:20 PM
Newbie Group: Members Posts: 5 Joined: 7-March 16 From: Texas Member No.: 19,734 Region Association: None |
Need to find a seller for that piece that connects the accelerator cable to the pedal cluster. Jim, this is not related to your question but I just replaced my accelerator cable and getting the ball cup back on the ball was a bit awkward. I used hose clamp pliers and it was easy. Doesn't answer your question but might help, don't know how to place image in my reply, sorry. If Pelican does not have it, try Zims Automotive in Bedford TX |
jim_hoyland |
Jun 23 2021, 09:36 PM
It’s been a long time since I had to clamp the cup back on; but, you are right it’s a tricky maneuver…. (IMG:style_emoticons/default/smile.gif)
bdstone914 |
Jun 23 2021, 10:29 PM
bdstone914 Group: Members Posts: 4,536 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Isn't there a pin that goes in there to ensure the socket stays on the ball? Not on 914's. There is an internal clip The ones on G50 pedal sets do have a pin that holds them on in addition to the ring clip. They can be used on a 914 but would be difficult to install. @Montreal914 |
Lo-Fi Version | Time is now: 7th June 2024 - 12:15 PM |
