jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,319 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
This switch cuts off the fuel pump ground if the switch senses an impact. The switch is reset by pressing the top of the switch.
Good way to turn off the fuel supply in the event of a crash or impact. Not an overly sensitive switch. (IMG:style_emoticons/default/agree.gif) Attached image(s) ![]() ![]() ![]() |
mlindner |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,529 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest ![]() ![]() |
Jim, tell us more about this. Are there stats on roll over, impact etc. Interesting. Mark
jim_hoyland |
Jim, tell us more about this. Are there stats on roll over, impact etc. Interesting. Mark Don’t know about that… (IMG:style_emoticons/default/confused24.gif) |
Puebloswatcop |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,389 Joined: 27-December 14 From: Mineola, Texas Member No.: 18,258 Region Association: Southwest Region ![]() |
Not sure about this particular switch since I don't know what vehicle it was designed for, but During my years I worked as a traffic accident investigator, I found these switches to be a valuable asset in stopping post crash fuel flow. Some were designed to cut off when sensing an impact of about 10 MPH and above and in a rollover the forces are such that it almost always will trip the switch.
The good thing is if the car has suffered an impact, but is still drivable, and the switch has been tripped, you simply hit the reset button and you're able to drive on. A good safety feature in most cases. |
914Toy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 718 Joined: 12-November 17 From: Laguna beach Member No.: 21,596 Region Association: Southern California ![]() ![]() |
Jim, tell us more about this. Are there stats on roll over, impact etc. Interesting. Mark Don’t know about that… (IMG:style_emoticons/default/confused24.gif) You have a PM. |
PanelBilly |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,817 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest ![]() ![]() |
I installed one that I got from Napa. It’s easy to test by giving it a smack with a dead blow hammer when the car is running.
mb911 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,883 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest ![]() ![]() |
Put one in my car. Very happy I did.
mlindner |
Ben, what model did you use. Mark
mb911 |
Lo-Fi Version | Time is now: 10th June 2024 - 09:14 AM |
