front wheel bearings for a 914-6, anyone have a press that can replace them for me? |
fixer34 |
Jun 26 2021, 06:18 PM
Senior Member Group: Members Posts: 1,087 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest |
As the heading says, I am on the slope of 'one more thing' while replacing the master cylinder. First it's have PMB rebuild calipers. Then replace front rotors. While they are off, do the wheel bearings.
I looked at the video, but that is for a -4. Not quite the same. And I don't want to mess up these hubs. So, anyone in the Chicagoland area that could remove the old races and press new ones in? I have the parts from PMB. I'll drive them over, or pack up and ship. |
914Sixer |
Jun 26 2021, 06:27 PM
914 Guru Group: Members Posts: 8,903 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Try taking them to a machine shop.
mepstein |
Jun 26 2021, 06:51 PM
914-6 GT in waiting Group: Members Posts: 19,313 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Old races will remove from the back with a punch. New races can be installed with a loaner race setting tool from your local auto part store. Heat the hub in the oven and tap in the race with the tool.
I have a friendly local mechanic who will do that kind of stuff for a few dollars. I drop it off in the morning and pick it up after lunch. Recently, I got tired of driving to my old shop so I bought a harbor freight 20 ton press. It was under $200 and I’ve used it quite a bit. It’s more than paid for itself. |
roblav1 |
Jun 26 2021, 06:55 PM
Senior Member Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
Front (and rears) pretty much slide in place after bearings in the freezer and heating the hubs.
fixer34 |
Jun 26 2021, 06:58 PM
bkrantz |
Jun 26 2021, 07:55 PM
914 Guru Group: Members Posts: 7,802 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
Front (and rears) pretty much slide in place after bearings in the freezer and heating the hubs. I was thinking about this; have to make sure ALL the grease is out if I use the wife's oven... Maybe swap in some bacon grease? (IMG:style_emoticons/default/dry.gif) |
mepstein |
Jun 26 2021, 08:06 PM
Wipe them clean and then use brake clean to clean them further. Or clean and bead blast. I leave the old races in, bead blast and then remove the races and install new.
worn |
Jun 26 2021, 11:44 PM
can't remember Group: Members Posts: 3,163 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
As the heading says, I am on the slope of 'one more thing' while replacing the master cylinder. First it's have PMB rebuild calipers. Then replace front rotors. While they are off, do the wheel bearings. I looked at the video, but that is for a -4. Not quite the same. And I don't want to mess up these hubs. So, anyone in the Chicagoland area that could remove the old races and press new ones in? I have the parts from PMB. I'll drive them over, or pack up and ship. I might be able to help. I live in Madison WI, but right now I am in Arizona. On my way home tomorrow. |
brant |
Jun 27 2021, 06:23 AM
914 Wizard Group: Members Posts: 11,639 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Steel punch
Brass drift No press necessary |
gms |
Jun 27 2021, 07:12 AM
Advanced Member Group: Members Posts: 2,695 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
Pete, I sent you a text
fixer34 |
Jun 27 2021, 08:51 AM
mb911 |
Jun 27 2021, 10:35 AM
914 Guru Group: Members Posts: 6,881 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Super easy in an oven they drop out and your done. I use a oxy torch
Lo-Fi Version | Time is now: 8th June 2024 - 03:59 AM |
