What to do with a spare 2.7? Buy a roller!, Back at it. |
Dr Evil |
Jul 8 2021, 08:09 AM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
A good running 2.7 came my way at a price I could afford and couldn’t refuse. Soooo, I bought it. Then, I was like, “what can I stick it in?” I already have my other 74 with a 2.7 CIS, the bus already has a big flat 6, I don’t own any ac VW to mess with, so I searched for a body. Found a well priced example close to me. Actually, only surface rust so far. 74 with parts, minus windshield, needs area forward of windshield repaired as PO did not do so correctly (solder and rivet, but good metal in place to weld). So, I plan to do some things with this. Some Evil things (IMG:style_emoticons/default/happy11.gif)
Attached thumbnail(s) |
Cairo94507 |
Jul 8 2021, 08:23 AM
Michael Group: Members Posts: 9,822 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
What a great way to get another car on the road. (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/beer3.gif)
914Sixer |
Jul 8 2021, 08:30 AM
914 Guru Group: Members Posts: 8,903 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Sweet project
Root_Werks |
Jul 8 2021, 08:59 AM
Village Idiot Group: Members Posts: 8,337 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Looks like some work has already been done. Get that painted and 2.7 installed! Yellow will make the 2.7 go faster.
worn |
Jul 8 2021, 04:14 PM
can't remember Group: Members Posts: 3,164 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
A good running 2.7 came my way at a price I could afford and couldn’t refuse. Soooo, I bought it. Then, I was like, “what can I stick it in?” I already have my other 74 with a 2.7 CIS, the bus already has a big flat 6, I don’t own any ac VW to mess with, so I searched for a body. Found a well priced example close to me. Actually, only surface rust so far. 74 with parts, minus windshield, needs area forward of windshield repaired as PO did not do so correctly (solder and rivet, but good metal in place to weld). So, I plan to do some things with this. Some Evil things (IMG:style_emoticons/default/happy11.gif) Seems destined to be yellow. Might try to mount a different wheel style to each of the 4 possible spots. Phone dial for the spare. Congrats! It is nice to see one of our heroes punished once again. |
PanelBilly |
Jul 8 2021, 04:21 PM
914 Guru Group: Members Posts: 5,817 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Do a wrap in a cray pattern!
Spoke |
Jul 8 2021, 08:21 PM
Jerry Group: Members Posts: 6,991 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
mepstein |
Jul 8 2021, 08:31 PM
914-6 GT in waiting Group: Members Posts: 19,314 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Dr Evil - Did you build the car you sent to Scotty
Dr Evil |
Jul 9 2021, 01:50 PM
Dr Evil - Did you build the car you sent to Scotty Sort of. I built the engine from the crank up from a 74 targa 2.7, changed it to SC cams, modified the CIS to fit (not much work for that). Rebuilt the transmission, brakes, etc. Body work is by Scotty, and interior will have to wait. Its forerunner was body, paint, and upholstery in TJ, Mexico. This car will likely be satin black, roller, might flare it to handle the engine mods I plan. |
Dr Evil |
Jul 9 2021, 01:51 PM
A good running 2.7 came my way at a price I could afford and couldn’t refuse. Soooo, I bought it. Then, I was like, “what can I stick it in?” I already have my other 74 with a 2.7 CIS, the bus already has a big flat 6, I don’t own any ac VW to mess with, so I searched for a body. Found a well priced example close to me. Actually, only surface rust so far. 74 with parts, minus windshield, needs area forward of windshield repaired as PO did not do so correctly (solder and rivet, but good metal in place to weld). So, I plan to do some things with this. Some Evil things (IMG:style_emoticons/default/happy11.gif) Seems destined to be yellow. Might try to mount a different wheel style to each of the 4 possible spots. Phone dial for the spare. Congrats! It is nice to see one of our heroes punished once again. (IMG:style_emoticons/default/whip[1].gif) This is the way. (IMG:style_emoticons/default/whip[1].gif) |
Dr Evil |
Jul 9 2021, 01:55 PM
Recon I will make my internal thoughts and plans public. I plan to attempts a twin turbo with the 2.7 I bought. It wont be the first, and I plan to copy the ideas of this evil genius that has come before. Read the postings of DPHANS and marvel. It is time to gather the parts.
http://forums.pelicanparts.com/911-930-tur...-2-7-turbo.html http://forums.pelicanparts.com/911-930-tur...kits-use-3.html |
mb911 |
Jul 9 2021, 02:17 PM
914 Guru Group: Members Posts: 6,882 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Recon I will make my internal thoughts and plans public. I plan to attempts a twin turbo with the 2.7 I bought. It wont be the first, and I plan to copy the ideas of this evil genius that has come before. Read the postings of DPHANS and marvel. It is time to gather the parts. http://forums.pelicanparts.com/911-930-tur...-2-7-turbo.html http://forums.pelicanparts.com/911-930-tur...kits-use-3.html Go with 993 heat exchangers then. I used those, ssi's, my own headers and found the 993 setup the best for my single turbo, dual waste gate, 3.2 short stroke efi engine. I ran 8.5-1 with 7 psi of boost and sc cams . It was an absolute monster. Wheel spin was almost uncontrollable in it with 17x12 Fuchs on the back. |
nivekdodge |
Sep 20 2021, 01:21 PM
Member Group: Members Posts: 250 Joined: 28-August 21 From: Pittsburgh Pa Member No.: 25,860 Region Association: MidAtlantic Region |
Are you still in Ingram? I just bought my first one and I’m in Moon. Great body but bad floors
Lo-Fi Version | Time is now: 9th June 2024 - 06:13 AM |
