Steering Column Play on converted 6 |
jhynesrockmtn |
Aug 9 2021, 10:07 AM
Member Group: Members Posts: 420 Joined: 13-June 16 From: spokane wa Member No.: 20,100 Region Association: Pacific Northwest |
My GT Clone was built back in the 90's originally out of a few factory 6 donors. It had a Momo wheel on it when I bought it and trying different configurations I'm wondering about how to reduce play in the column and if I have the correct parts in there. I've attached a few pics. If I use the short adapter that came with the removable wheel kit it goes in deep enough to reduce the play by sandwiching in between what looks like a bearing and the column. I have no spring in there. If I use the short hub only the wheel is too far away. Hopefully this makes sense.
jhynesrockmtn |
Aug 9 2021, 12:47 PM
I was just trying to measure for a spacer and even with the short hub there is a lot of play. what parts am I missing? I've looked at the Auto Atlanta parts diagrams and can see I'm missing a spring but that won't take up the slack with no bearing meeting the column, correct?
mb911 |
Aug 9 2021, 01:18 PM
914 Guru Group: Members Posts: 6,903 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I can't help other then say that with a stock wheel it fits fairly snug in the front bearing which is what I think is your issue. I don't think your adapter fits inside the bearing.
SirAndy |
Aug 9 2021, 01:42 PM
Resident German Group: Admin Posts: 41,688 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I got one of them to make sure the shaft doesn't wobble inside the bearing.
Attached image(s) |
jhynesrockmtn |
Aug 18 2021, 07:12 AM
914Sixer |
Aug 18 2021, 08:38 AM
914 Guru Group: Members Posts: 8,912 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Wheel is the centering device for the column.
mb911 |
Aug 18 2021, 09:18 AM
I still don't think that's your problem. I think it's your wheel itself is not the right diameter(the part that slides into the column)
DavidSweden |
Aug 18 2021, 12:34 PM
Member Group: Members Posts: 479 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
jhynesrockmtn |
Aug 23 2021, 07:21 AM
I still don't think that's your problem. I think it's your wheel itself is not the right diameter(the part that slides into the column) Thanks for this idea. I have a couple of Momo hubs but ordered one that states it fits 911 pre 74. Looks like it has a longer extension into the column. |
Lo-Fi Version | Time is now: 16th June 2024 - 10:55 PM |
