Axle CV joint bolts question |
roundtwo |
Aug 10 2021, 04:14 PM
Member Group: Members Posts: 282 Joined: 9-February 20 From: Petaluma, CA Member No.: 23,905 Region Association: Central California |
Hello
Can someone kindly tell me … see pic. 1. The bolts that hold this together, should I use lock tight on them. The heads arent drilled to wire fasten for back up safety. 2. torque spec for the bolts. ? Assuming it’s the same on both ends of the axle ? Close to finishing up my caliper/ brake/ rotor/ bearing install on all four corners Attached thumbnail(s) |
76-914 |
Aug 10 2021, 04:22 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
You can drill them out while its convenient or order them drilled out. Otherwise you will need to recheck them occasionally. 38 ft lb's IIRC. No lock tite but new schoor washers each time if your not safety wiring them (IMG:style_emoticons/default/beerchug.gif)
roblav1 |
Aug 10 2021, 07:41 PM
Senior Member Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
Never ever put locktite on those! Use new Schoor washers.
roundtwo |
Aug 10 2021, 11:27 PM
Thanks for all your help. I had no idea what those washers were called learn some thing useful every day.
I think it’s super slick to wire them. Off to the auto parts store AGAIN for the correct washers. Torque wrench ready. Cheers |
Mikey914 |
Aug 11 2021, 12:58 AM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
The Schoor washers are a good way to go. We do sell the bolts premachined, you don't have to do every one to safety wire them.
But at .20 each the washer is a cheap way to go, just don;t try to reuse them. https://914rubber.com/schnorr-washer-for-8mm-1 Attached thumbnail(s) |
Bartlett 914 |
Aug 11 2021, 10:24 AM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
I do agree on the proper washers. I have discovered that the biggest problem with the CV's working loose is a distorted output flange at the transmission. Once a CV has worked loose, the flange gets a little distorted. It is like the threaded portion is pulled out creating a high spot at the threads. The flange must me perfectly flat. If is isn't, no matter what washers you use it will work loose again. I use a lathe and make a very small cleanup cut.
brant |
Aug 11 2021, 04:13 PM
914 Wizard Group: Members Posts: 11,640 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I doubt the parts store carries those Schnorr washers.
always new. even if you loosen one and re-tighten it. If its a brand new correct schnorr washer it will hold. I think I use 31ft. lbs. the reused washers will always come loose and need a re-torque the new washer will not come loose. |
Lo-Fi Version | Time is now: 10th June 2024 - 01:00 PM |
