Transmission fittings/plugs for use with coolers??, what hardware used??? |
Mueller |
Jul 25 2005, 11:20 AM
Is there a standard AN fitting adapter that'll screw into the fill and drain openings of the transmission??
What are people using?? |
ArtechnikA |
Jul 25 2005, 11:41 AM
as AN fittings are ALWAYS English parallel threads and the standard fill and drain plugs are metric tapered pipe plugs, Question #1 would be a "no."
several people have reported drilling through the fill and drain plugs and welding/brazing/JB-gluing some kind of fitting. i'd recommend using the 19mm ATF 911/914.6 plugs for this, rather than the 17mm Inhex (Allen) plugs that are standard in the 914.4 the fill plug is 999.064.019.02 and the drain plug (with magnet) is 999.064.020.02. |
Mueller |
Jul 25 2005, 11:52 AM
Hi Rich, you must not have seen the word adapter in my question (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
Good idea on the 19mm external head...I'll look into it....thanks |
joea9146 |
Senior Member Group: Members Posts: 663 Joined: 10-February 03 From: Denver, NC Member No.: 283 Region Association: None |
I have 2 Transmission plugs that will fit. They are Metric on one end
and 12an on the other side. I will sell them for what i paid. I never used them. I will cover the shipping if you are interested. |
Mueller |
Jul 25 2005, 11:54 AM
you have a PM on it's way (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif)
ArtechnikA |
Jul 25 2005, 11:55 AM
i expect Mike will jump on those, but if not, can i be next in line?
lacking that, where did you get them ? Mike - you're right - i didn't see the adapter part... |
john rogers |
Jul 25 2005, 12:13 PM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
I made my suction fitting by drilling and pipe taping a regular drain plug and using the pipe to AN adapter. After I tightened the adapter I used some JB Weld just to make sure it held. So far in 4 races it has worked well. For the return we also used pipe to AN adapters.
Lo-Fi Version | Time is now: 4th June 2024 - 11:47 PM |
