Who makes custom length throttle cables? |
PatrickB |
Aug 23 2021, 02:39 PM
Member Group: Members Posts: 249 Joined: 26-March 17 From: sw ontario Member No.: 20,960 Region Association: Canada |
Hopefully in Canada? Running into a problem, see the diesel build thread.
bbrock |
Aug 23 2021, 03:13 PM
Terry Cable will make them to specified length if you call them.
PatrickB |
Aug 24 2021, 11:57 AM
bbrock |
Aug 24 2021, 12:12 PM
Google is your friend
http://www.terrycable.com/ |
Maltese Falcon |
Aug 24 2021, 12:24 PM
Advanced Member Group: Members Posts: 4,694 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
Controlcables.com ask for Greg.
In Santa Fe Springs, California They build any type of cable...just give them the specs. Marty |
76-914 |
Aug 24 2021, 06:16 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,508 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Controlcables.com ask for Greg. In Santa Fe Springs, California They build any type of cable...just give them the specs. Marty I've ordered custom shifter cables form them but did not know they'd make accelerator cables. They're great guys. EDIT: I wonder if they'd do clutch and speedo cables for the 914 also. There have been lots of complaints about what is currently available. |
r_towle |
Aug 24 2021, 08:59 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
A high end bicycle shop, seriously.
Maltese Falcon |
Aug 25 2021, 12:01 AM
Controlcables.com ask for Greg. In Santa Fe Springs, California They build any type of cable...just give them the specs. Marty I've ordered custom shifter cables form them but did not know they'd make accelerator cables. They're great guys. EDIT: I wonder if they'd do clutch and speedo cables for the 914 also. There have been lots of complaints about what is currently available. When I was over at their shop, they have every size /shape of push, pull, stranded, ball end, barrel end, accelerater, park brake, choke, etc. My SQS sequential shifter came from Czech Republic with a Too-short of a shift cable; set up for rear engine 996gt2 transaxle. I gave ControlCable the correct length (for mid-engine use), the cable-end description, and the unit that they custom made was Spot On. Now working on my accelerater cable for the Tilton pedal set. (IMG:style_emoticons/default/marty914.jpg) |
HansJan |
Aug 25 2021, 10:23 PM
Member Group: Members Posts: 395 Joined: 5-April 16 From: Sugar Land TX Member No.: 19,860 Region Association: Southwest Region |
Do NOT buy the Terry cable.
I did.... But the part that runs through the tunnel comes without outer sleeve. I can feel it rubbing against other stuff in the tunnel, so its not going to last very long. Ordered a replacement cable from 914 Rubber. They did make custom length for me (added length to reach the carb- X-bar). Good luck |
PatrickB |
Sep 6 2021, 03:44 PM
Just pulled mine out and don't see any issues. What could have happened inside the tunnel ? it worked fine for a couple of years and then started binding up. The plastic sleeve over the cable does have a little cut on it in one spot but feels like it's working fine. Going to order a new custom length cable maybe from 914 rubber but I think the probem is elsewhere.
PatrickB |
Sep 9 2021, 03:48 AM
Just pulled mine out and don't see any issues. What could have happened inside the tunnel ? it worked fine for a couple of years and then started binding up. The plastic sleeve over the cable does have a little cut on it in one spot but feels like it's working fine. Going to order a new custom length cable maybe from 914 rubber but I think the probem is elsewhere. Tried sending email to 914 rubber from their website a few days ago.... no answer. Anyone got a good email address for them? |
Lo-Fi Version | Time is now: 8th June 2024 - 10:38 AM |
