heater lever wiring |
dt4 |
Aug 30 2021, 08:18 AM
Senior Member Group: Members Posts: 503 Joined: 26-May 19 From: England Member No.: 23,161 Region Association: England |
Hi,
Could anyone tell me the colour of the wire that goes to the heater lever please A photo would be great help thanks |
rhodyguy |
Aug 30 2021, 08:20 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,084 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
For the ground tab?
mepstein |
Aug 30 2021, 08:38 AM
914-6 GT in waiting Group: Members Posts: 19,307 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
dt4 |
Aug 30 2021, 10:30 AM
Aaahh of course I should have figured that
what triggers the fan to run then, does the lever make a connection in the up position? I dont recall there being an earth wire off the loom in that area, I'll re assess thank you both |
rhodyguy |
Aug 30 2021, 12:11 PM
When the nub on the lever arm bottom contacts the ground tab, the engine compartment fan kicks on.
IronHillRestorations |
Aug 30 2021, 01:47 PM
I. I. R. C. Group: Members Posts: 6,724 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
It's white with a green stripe. It activates the heater fan relay in the engine compartment via grounding.
dt4 |
Aug 30 2021, 01:57 PM
Aug 30 2021, 06:17 PM
It's white with a green stripe. It activates the heater fan relay in the engine compartment via grounding. not a brown ground / earth wire then? No, because it triggers the fan relay, so it's not a common ground. I was wrong on the color coding, it's green with a white stripe |
dt4 |
Aug 31 2021, 12:42 AM
It's white with a green stripe. It activates the heater fan relay in the engine compartment via grounding. not a brown ground / earth wire then? No, because it triggers the fan relay, so it's not a common ground. I was wrong on the color coding, it's green with a white stripe thank you |
dt4 |
Aug 31 2021, 11:02 AM
It's white with a green stripe. It activates the heater fan relay in the engine compartment via grounding. not a brown ground / earth wire then? No, because it triggers the fan relay, so it's not a common ground. I was wrong on the color coding, it's green with a white stripe found it, it had been cut back for some reason so I connected an additional length of wiring and a connector to it and attached it to the spade connector on the lever..... but nothing happened, the fan didnt kick in when the lever is pulled up Im struggling to see how the lever makes a connection to be honest. (IMG:style_emoticons/default/confused24.gif) |
iankarr |
Aug 31 2021, 11:25 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,480 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Check that the relay in the engine compartment is good and properly seated. As for the signal path, think of the lever as a ground interrupt.
Aug 31 2021, 11:52 AM
You can unplug the motor and test it by connecting to the battery. On the motor green is positive and brown is ground. I'm guessing you have a bad fan motor, or as Ian suggested a problem at the relay.
They used a relay that's triggered by grounding, so there's no power going to the switch on the heater lever. If you're not sure how a relay works, check this out How a relay works |
dt4 |
Aug 31 2021, 01:11 PM
I checked the blower before fitting it so that parts ok
I need to check the relay, can anyone short cut me by pointing out which it is please thank you oh, and how do I check the relay sorry for all the Q's |
NARP74 |
Aug 31 2021, 01:22 PM
Senior Member Group: Members Posts: 1,072 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
Once again I am having a similar issue. Basically whatever is written about, I am working on. I started at the fan, only 2 wires, ground and power IIRC. I just used a powerprobe to trigger the fan and it works there, but not via the lever. So I am backtracking to find the culprit. Probably test the relay next.
Can you swap the 2 relays on the board for testing? I think they are the same. |
iankarr |
Aug 31 2021, 01:26 PM
Easiest way to check relay is to pop off the covers next to the headlight motors and swap it in. If the motor works as usual, the relay is at least mostly functional. (IMG:style_emoticons/default/smile.gif)
rhodyguy |
Aug 31 2021, 01:50 PM
I forget (and don't run an aux engine fan), does the key have to be turned to the first position to power the fan?
mepstein |
Aug 31 2021, 01:53 PM
I never ran an engine fan either. Plenty of heat, even in sub freezing weather.
rhodyguy |
Aug 31 2021, 02:08 PM
Yep.
dt4 |
Sep 1 2021, 12:42 AM
NARP74 |
Sep 1 2021, 08:20 AM
I run it to try and dissipate engine heat. Not sure if it works that way though.
Lo-Fi Version | Time is now: 1st June 2024 - 12:42 PM |
