Parking brake cable boots, what's the trick? |
fixer34 |
Aug 30 2021, 03:44 PM
Senior Member Group: Members Posts: 1,085 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest |
I bought a set of front/rear rubber boots from 914Rubber for the parking brake cables. In my ignorance, I figured I could stretch them over the caliper clevis end. Not happening. So what is the trick to replacing them? Thought I needed to pull the cable out of the housing, but looking at a diagram, there are 'big' ends on both.
Am I just not stretching the boot enough? |
914Sixer |
Aug 30 2021, 05:02 PM
914 Guru Group: Members Posts: 8,897 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
There is NO TRICK. I have tried both 914Rubber and URO. The rubber compound must be too hard and does not NOT STRETCH. The only thing I forgot to try is boiling them to see what will happen. All I can say is you are not alone.
IronHillRestorations |
Aug 30 2021, 06:24 PM
I. I. R. C. Group: Members Posts: 6,724 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I've used a pair of snap ring pliers to stretch rubber boots
JeffBowlsby |
Aug 30 2021, 09:24 PM
914 Wiring Harnesses Group: Members Posts: 8,524 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
The last set I bought from Porsche were easy to put on. How about liberal amounts of lube? Try glycerine.
adolimpio |
Aug 31 2021, 06:24 PM
Art Group: Members Posts: 182 Joined: 10-March 10 From: Greenwood SC Member No.: 11,449 Region Association: South East States |
Silicone o-ring grease, muscle and patience.
I got mine from 914 Rubber and they were surprisingly strong. I stretched the crap out of them to get them on, and was sure they would tear, but they held up nicely. |
fixer34 |
Aug 31 2021, 08:02 PM
Silicone o-ring grease, muscle and patience. I got mine from 914 Rubber and they were surprisingly strong. I stretched the crap out of them to get them on, and was sure they would tear, but they held up nicely. That's where I got them, so I'll give it another go sometime when I have a bit more of the third item... |
bkrantz |
Aug 31 2021, 08:43 PM
914 Guru Group: Members Posts: 7,791 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
fixer34 |
Sep 12 2021, 02:42 PM
Silicone o-ring grease, muscle and patience. I got mine from 914 Rubber and they were surprisingly strong. I stretched the crap out of them to get them on, and was sure they would tear, but they held up nicely. That's where I got them, so I'll give it another go sometime when I have a bit more of the third item... These three did it. Wire brushed the clevis end to get all the crap off, lubed it and the boot up and with judicious stretching got them on. Based on this, if Mikey ever needs a sideline, he should go into the condom business. Not sure about comfort, but they would certainly stretch to fit and no worries about failures. '914Rubber rubbers'- has a catchy sound to it... |
DRPHIL914 |
Sep 13 2021, 07:52 AM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Silicone o-ring grease, muscle and patience. I got mine from 914 Rubber and they were surprisingly strong. I stretched the crap out of them to get them on, and was sure they would tear, but they held up nicely. That's where I got them, so I'll give it another go sometime when I have a bit more of the third item... These three did it. Wire brushed the clevis end to get all the crap off, lubed it and the boot up and with judicious stretching got them on. Based on this, if Mikey ever needs a sideline, he should go into the condom business. Not sure about comfort, but they would certainly stretch to fit and no worries about failures. '914Rubber rubbers'- has a catchy sound to it... (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/happy11.gif) i did this yesterday and boy are they tight, yet somehow stretchy. got them on and look good! I was surprised that 914rubber does not carry the cables but got them from Sierra Madre, they are made in europe, and fit and work perfectly but dont come with the boot for the ends, so glad 914rubber and URO make these. |
Lo-Fi Version | Time is now: 1st June 2024 - 05:07 PM |
